wiring question for running lamps
Hello thanks for looking in... I installed 2 LED for running lamp/fender marker light. I currently have it hooked to the headlamp tab of the ignition. I was wondering if I can Y the power feed to be on when I roll the ignition into the acc tab? So there will be power from the light or Run tab and then if I roll past I can have the fender light on in acc. Will the two tabs being connected to via the Y I solder be a problem or double draw? I know the Acc tab is not hot till I turn the switch to Acc. Any thoughts?
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
