ProCharger.comMotorcycle.com Classifieds!
American Side Road CycleSportbikeTrackGearAdvanstarMotorcycleShowsDan Vance RacingBub EnterprisesRRcycles.com
Motorcycle.com
Old 10-10-2009, 05:13 PM   #1 (permalink)
hbmc's Avatar
changing stator question??
Thanks for looking in....
I am currently changing my Stator and the Boot or Grommet that goes thru the block or case is that come on the new part of the Stator?
It disintegrated on removal so I cannot tell if the Stator is going to have the "what appears to be a Grommet or Boot" attached or with the the replacement?
Or is there a separate grommet that I need to get?
Thanks for your help
Regards,
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
Old 10-10-2009, 06:25 PM   #2 (permalink)
kemo is on a distinguished road
The seal plug comes on the stator harness
kemo is offline   Reply With Quote
Old 10-10-2009, 08:00 PM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
Yup, like kemo said, should come on the stator. Lube it up good before pushing it though.
Carefull on the screw tq and you should be golden.
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 10-10-2009, 10:32 PM   #4 (permalink)
hbmc's Avatar
thanks guys I was wondering if it comes on the stator end or not. got it on order from JP the Dealer wanted 210 plus tax for just the stator and regulator. I got new low profile gas caps--new stator--new regulator---2 extra Primary gaskets---new mirrors (which are so cool)---new master cylinder cover---cruise control thumb wheel and parts plus a head lamp sealed beam retaining ring and the torx screws delivered for 325
Oh and the best place I found for new headlamps as opposed to the 70 bucks online and who knows at the Dealer but Pep boyz for 20 bucks nice blue tint so it is nice at night!
1991 flstf 'fat-boy
2-1 White "E-pipe"
Old 10-10-2009, 11:37 PM   #5 (permalink)
strokerjlk's Avatar
did you loosen the set screw behind the shifter shaft?
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
strokerjlk is online now   Reply With Quote
Old 10-11-2009, 12:44 AM   #6 (permalink)
hbmc's Avatar
If you are referring to the two set screws and plastic keeper? Yes.
1991 flstf 'fat-boy
2-1 White "E-pipe"
Old 10-23-2009, 12:54 AM   #7 (permalink)
hbmc's Avatar
Whew that was a close one---for some stupid reason ( idunno)
I looked up specs for torx for stator and read 40 so I set the torque wrench to 40lb and I get to tightening and I say hmmm that feels like the sweet spot of bottoming out or near strip! Frikin 40 inch pounds!! So what does that equate to in foot lbs 2?
Geez I hope I do not snap the heads off those when and if I got to get in there>>?
Boner delucx!
So anyways all back together I had the parts on order so in the interim I drained the forks new headlamp went thru electrical got a new chrome regulator new boards (thanks Gunny)
Called the Uniqcycle guy and he tells me I got 5 years... Told me send him the old speaks and he will ship out the new and improved. No charge just mail from me to him.
So new sound---Yeaaaahhh!
Gonna give that new charging system something to do. Oh that Rubber end on the stator to get that up there (interesting and tricky) Here goes---Lube hole with rtv (light) as you insert the rubber end you have to position the stator so you do not get any resistance. (tugging or ??)
as you position the rubber end (from the outside of the case (use small needle nose pliers to pull) When you pull the rubber end thru (very tight fit) you need to coax the rear of the boot with a driver or the likes of and shove it as you pull it. Make sure you RTV the remainder of the plug and hole, then snug your two screws that hold the boot in place. I took the liberty while there to coheres some rtv at the bottom side of the case---where the o ring meet (inner outer pmary). Resist leaks I hope?
Of course I had to buy some goodies too.
So I got these skull hand bone mirrors that are holding coffins (not to obtrusive have to get within 3 feet to see the detail. Like the rest of my sculptures on my tank and fenders.
Low profile gas caps that seem to get so tight that I need a microwave or gamma rays to get them off
(you don't want to see me angry :HULk)
Gonna try rainex on the windshield (gotta get rid of the fog I get at the beach)
All right then so I rebuilt my Tranny (shifting pawl spring)
New Stator and Regulator ( melt down)
Milled the rear jug (to get rid of seepage)
This year "knock on wood"
Gonna let the loctite dry and get some new hardware (chrome bolts) and hopefully burn a few tanks of gas before Sunday. Thanks to everyone who helped out and input and suggested throughout all of these adventures.
Regards
1991 flstf 'fat-boy
2-1 White "E-pipe"
