Leslie Kay'sBub Enterprises
JekillandHyde.euSportbikeTrackGearRRcycles.comMotorcycle-CommunicationMotorcycle.com
Old 09-28-2009, 07:32 PM   #1 (permalink)
Old married guy
vindex1963's Avatar
high output headlight
My buddy at work bought a two pack of 12v 100/90w H.I.D. look super white headlight bulbs. They are made at Bluhm Enterprises. 98% Xenon gas.
Question is are these things stator killers or run so hot they melt the bulb plug or socket?
That's his original bulb that he replaced because it was burning.
I like the thought of more visibility/
2009 FLHTCU Ultra Classic
Vance & Hines Fuel Pak
Vance & Hines Slip-Ons
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 09-29-2009, 04:23 AM   #2 (permalink)
The Anti-RUB
petrock's Avatar
From what I've read the Xenon bulbs aren't really that bright. At least not compared to Sylvania's SilverStar Ultra's. You can pick them up at any local auto-parts store. A bit pricey but worth it. They are on sale all the time in my area. I have them installed on all my vehicles and love them. Long lasting, and great visibility in the stock headlight shell. Better then HD's Screamin' Eagle 'performance' bulb by far. Silvania's web site doesn't list motorcycles in their fitment guide, but their paperback catalog does. My ride takes part # 9003/HB2 (which is the same as the H4).
Due to the amount of watts those Xenon bulbs use, I would definitely be worried about excessive heat.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 09-29-2009, 11:34 PM   #3 (permalink)
HDSG is on a distinguished road
Better Solution for Brighter Light.
I have a better solution for the light issue. I contacted Daniel Stern Lighting after reading about his lighting expertice.
He told me the biggest problem with the headlamp system on my2006 SG was the reflector assy. After talking to him I purchased a Cibie Reflector and a Oshram H4 lamp. WOW, what a difference. No overheating, no relays, just plug and play. Great Upgrade. Call Daniel Stern Lighing.
HDSG is offline   Reply With Quote
Old 09-30-2009, 07:17 AM   #4 (permalink)
lschultz
You talked to the man that knows about lighting Daniel Stern. My son and I bought his Cibie lights several months ago and the bulbs he recommended and a big big improvement. Plug it in and go. The problem is the refractors HD use. Probably made in China so HD uses them.
Larry Schultz
Cistern,Tx
09 FLHTCU
09 FXSTC (son's bike)
Amsoil Dealer
08 Vespa GTS
07 Ural Patrol- For sale
lschultz is offline   Reply With Quote
Old 09-30-2009, 10:05 AM   #5 (permalink)
I am not sure it has to do with the manufacturer as much as the design. Harley chose form over function. The clear lense looks cool but does a poor job of reflecting light. The Cibie reflector shines a wide curb to curb beam width and pushes a good beam straight down the road. I am a happy camper. Glad you experienced the same.
Old 09-30-2009, 03:00 PM   #6 (permalink)
Old married guy
vindex1963's Avatar
Glad to hear about what everyone is using but my original question was about the lights pictured.
"petrock" thanks for the response.
Sounds like employees for Daniel Stern are on the site.
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 09-30-2009, 03:33 PM   #7 (permalink)
Kenney is on a distinguished road
OK, 100/90 Watts lights draw 7.7 - 8.3 amps on a 12 volt system.
the Silverlight H4 are 55/60 watts (same as stock lights)
they draw 4.6 - 5 amps.
That is double the heat (watts) that you are going to get in your headlight housing (burning the plastic light base, see your pictures). Putting the Maxium current on your wiring and fuse/ circuit breaker for the headlight.
Sure you don't want to try the Silverlights?
Kenny's
05' ULTRA
GMR's 98" Kit (9.7:1CR)
_____________________________________________
Kenney is offline   Reply With Quote
Old 09-30-2009, 03:44 PM   #8 (permalink)
tthumper85 is on a distinguished road
My brother just bought an 09 nightster and was complaining about his headlight. anyone know what type silverstar the nightster takes?
tthumper85 is offline   Reply With Quote
Old 09-30-2009, 03:52 PM   #9 (permalink)
The Silverstrar H4ST is for motorcycles and is 60 watts.
These last a little longer but cost about $22. each.
Kenny's
05' ULTRA
Old 09-30-2009, 08:50 PM   #10 (permalink)
Old married guy
vindex1963's Avatar
I'm giving him back his bulb. I think the factory one is bright anyway.
I don't want melted anything.
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 10-01-2009, 01:00 AM   #11 (permalink)
Conneaut Rick's Avatar
Conneaut Rick is on a distinguished road
Yes they will melt your plug and/or blowyour fuse. Been there done that. When you go high beam it will draw too many amps and that fuse will blow right when you need it the most. Plus on an ultra ya all ready have alot on your stator anyhow, so ya should'nt push it.
Conneaut Rick,
'01 Night Train
Custom Paint by Jazzy, Ashtabula Ohio
116hp 103torque
95" Wiseco 10.5:1 pistons
52mm Horse Power inc. throttle body
T-mann heads
Crane 296 cam
D&D Fatcat exhaust
Power Commander tuned by Eric at Horse Power Inc.
2009 Horse Power Dyno shoot out winner Roar on the Shore Erie Pa.
Conneaut Rick is offline   Reply With Quote
Old 10-01-2009, 05:08 AM   #12 (permalink)
WOW, Really sorry. I thought I was helping you by giving you another solution. Anybody that reads the forum knows that the high watt bulbs draw too much current which causes heat........DAH.??????
In the future I will put you on my drop dead list and I won't try to give you any help.
Old 10-01-2009, 07:32 AM   #13 (permalink)
semi-retired
FatBobRob is on a distinguished road
Have you checked the voltage at the headlight yet?
I can't means I won't!
FatBobRob is offline   Reply With Quote
Old 10-01-2009, 08:46 AM   #14 (permalink)
FXDRYDR is on a distinguished road
Thanks to all. Didn't think about possible excessive heat on going with one of these. Still on the original bulb in my 03 and was thinking of going HID. Guess I'll stay with another stocker.
FXDRYDR
2003 FXD
98" Small Bore
107HP/113TQ
FXDRYDR is offline   Reply With Quote
Old 10-01-2009, 11:44 AM   #15 (permalink)
Old married guy
vindex1963's Avatar
OK.
I was looking for help on what I had listed and really wasn't looking for sugestions. This is an open forum and we are really just talking so if I'm on your DDL cool keep there you are far to sensitive.
S/E air cleaner
Stage 1 download
Mobil 1 everything
