I've changed plug wires with the tank on and lifted. It was a bit of a PIA. But the coil I am thinking you need to pull the tank.
While you got the tank off think of changing map sensor, its about $45, and easy to do with tank off. PIA with tank on.
You can loosen tank and see how it is, but taking tank off while be more pleasant. Maybe good time to think about quick release coupling for cross over house too. Ya how far do you go.
