Bub Enterprises
American Side Road CycleProCharger.comLeslie Kay'sCustom DynamicsAdvanstarMotorcycleShowsMotorcycle.com Classifieds!Diamond Bar Choppers
Custom Dynamics
Old 09-13-2009, 10:46 AM   #1 (permalink)
YamaChick is on a distinguished road
Something bad happened
I got these great fog lamps for my 08 Electra Glide. I drilled the bars, ran the wires, tied into the accessory plug under the seat, so I could use the switch on the fairing. Everything worked great until I used the cigarette lighter then POOF! No Fog lights, no lighter, Zip. All the Fuses in the fuse block look good. Any suggestions? I cant even locate the fuse for the Cigg lighter, I know it has to have one somewhere. I wasn't aware the the cigg lighter had anything to do with the Accessory switch. Apparently I am in over my head, Please help!
YamaChick is offline   Reply With Quote
Old 09-13-2009, 10:59 AM   #2 (permalink)
Greg MacD's Avatar
Greg MacD is on a distinguished road
You are pulling too many amps. You will need to run a dedicated power line for your fog lamps, using a relay is your best option. I would secure everything and bring the bike to someone who knows how to run the wires. I would think a car stereo place, or a small bike shop should be able to take care of you, if you play with the wires and do not know what you are doing, you run the risk of starting a fire.
2006 FLHTPI
2003 Aprilia RST 1000
1999 Victory V92C
Proudly serving the citizens of the United States in the United States Coast Guard, 1988-Present.
Greg MacD is offline   Reply With Quote
Old 09-13-2009, 11:03 AM   #3 (permalink)
Greg MacD's Avatar
Welcome
I just noticed you are new to the forum, welcome, I am just down the road in New Port Richey.
2006 FLHTPI
1999 Victory V92C
Old 09-13-2009, 11:06 AM   #4 (permalink)
Thanks Greg, I'm all over the amp thing. What's the lighter have to do with the blank accessory switch? gotta be tied in somehwere.
Old 10-02-2009, 06:23 PM   #5 (permalink)
KennyCoe is on a distinguished road
I'll bet the cig lighter is tied into the ACC circuit ahead of the ACC switch if it will work whether the switch is on or not, so when you pushed in the lighter you pulled too big a load and blew a fuse or a fuse link. Did you pull the fuses to check them? I have also seen blown fuses look just fine but wouldn't pass a continuity check with a meter.
kenny
KennyCoe is offline   Reply With Quote
Old 10-03-2009, 06:48 PM   #6 (permalink)
Global warming enthusiast
ACfixer's Avatar
ACfixer is on a distinguished road
Yeah there is a fuse labeled "ACC" in the box somewhere, you should also have one or two labeled "spare". In my bike it's a 15 amp fuse, go ahead and swap it just to check.
I would guess you will need a separate circuit via a relay to do that job. Did the directions that came with the fog lights suggest that or?
2005 FLSTCI Heritage Black Cherry/Black Pearl
ACfixer is offline   Reply With Quote
Old 10-03-2009, 06:55 PM   #7 (permalink)
boston rg is on a distinguished road
The hd ones use the "b" connecotor under the seat for power but you can use the acc plug/switch to pull the relay.
boston rg is online now   Reply With Quote
