CycleGear.comProCharger.comMBO EnterprisesRRcycles.comJardineProducts.com
Motorcycle-CommunicationDan Vance Racing
Old 09-11-2009, 04:32 PM   #1 (permalink)
caseyphill's Avatar
caseyphill is on a distinguished road
Light problems
I was working on a side mount. Splicing the wires to get the lights to work somehow I messed something up. i took the splices off and now....
The head light and rear tail light both work.
3 of the 4 running lights do not work now. When I hit the turn signals all 4 will work??
caseyphill is offline   Reply With Quote
Old 09-11-2009, 04:40 PM   #2 (permalink)
tazdevl20062008 is on a distinguished road
The Turn signal is a separate wire that sends a separate signal. So the lights may not come on as running lamps, but will still work as turn signals. Sounds like your lights aren't getting the power from the ignition. How did you splice them?
tazdevl20062008 is offline   Reply With Quote
Old 09-11-2009, 04:44 PM   #3 (permalink)
caseyphill's Avatar
i was using a crimp splice, whats got me messed up is left front running light comes on but the other 3 arent working..
Old 09-11-2009, 05:26 PM   #4 (permalink)
it's hard to help you without an electrical diagram. It's usually something basic like a bad ground or u forgot to attach a couple wires.
Old 09-11-2009, 05:54 PM   #5 (permalink)
caseyphill's Avatar
Well I took the crimps and additional wires off, so there are no additional wires are attached to the harness I was splicing into, but still having the same problem. thanks for the help Taz
Old 09-11-2009, 07:41 PM   #6 (permalink)
the best thing for u is to get a test light if u dont have one already, and check each wire one by one as you SOLDER them together to be sure each wire is doing it's job... as they pointed out above, go to your local dealer and have them print you out a diagram - it's really easy, all the wires are color coded
Old 09-12-2009, 10:03 PM   #7 (permalink)
LoneEagle964's Avatar
LoneEagle964 is on a distinguished road
on the rear unless they changed things there should only be your taillight,the rear turn are only turn signals unless you added a module to make them running lights. the front turns also are running lights start at the bulb and work back untill you find the power with a VOM
LoneEagle964 is offline   Reply With Quote
