Go through the tests in the book. You either have (in order of probability, my opinion): Bad wires to the pickup in the cone, bad pickup in the cone, bad ignition module, bad wires between stuff, bad coil, no power to the coil/system. Unless you have an aftermarket ignition, then that moves to the top of the list. A volt-ohm-meter and an hour should tell you what or give you a pretty good idea.
Dr.Hess
http://www.drhess.net
"71"
