Yep, know that the starter relay is part of the ignition circuit.
95 Softail has 3 circuits off the ignition switch, ignition with starter relay, lighting and accessory. Each with thier own terminal.
So with the newer switch with only two outputs, two circuits need to feed off one connection. Got to ck a stock wiring diagram from a newer bike today.
Looks like when they went to the electrical speedometers they went to 4 circuits.
One lead off the switch handles ignition, lighting and gauges and the other is dedicated to accessories. Kinda like I thought only with one more circuit.
Now if I could get a look at a 96 Softail parts book to get the part # for the housing for the spade terminals...
Not that it can't be wired without it, just would clean it up and avoid any confusion putting the wires back on anytime it was unplugged.
Originally Posted by route66paul
combined relay and ignition. You do not want to run the full power through the switch, this is why they make relays.
