JekillandHyde.euJardineProducts.comMBO EnterprisesDiamond Bar ChoppersAmerican Side Road CycleSportbikeTrackGearMotorcycle-CommunicationCustom DynamicsFuel MotoProCharger.comBub Enterprises
Custom Dynamics
Old 08-15-2009, 08:11 PM   #1 (permalink)
lowrider13's Avatar
lowrider13 is on a distinguished road
stalls at stop
In the last 2 months , my bike stalls at a stop. I watch the rpm's go to zero and the bike pukes. It starts right back up and won't have a problem for another week or so. Any ideas??
07 lowrider
rinehart 2-2 flush
cobra fuel mgt
custom bonekeeper tank
HE WHO THROWS DIRT...... LOSES GROUND!!!
lowrider13 is offline   Reply With Quote
Old 08-28-2009, 02:20 AM   #2 (permalink)
snowmaninwhite is on a distinguished road
air fuel ratio??? i had a similar problem... just a thought
snowmaninwhite is offline   Reply With Quote
Old 08-30-2009, 10:45 PM   #3 (permalink)
KPB46 is on a distinguished road
Mine does the same thing. I found the following on another forum. Tried it today. We'll see. Does seem the idle better tho
I did some searching on the Internet and found that the IAC valve plunger sticks and can cause this problem. I cleaned it and after a 70 mile ride, no more erratic idle problems! Hope it stays that way. Here's the notes I made about how to do this cleaning:
HARLEY 2006 EGC ERRATIC IDLE SPEEDS FIX
Pull the air filter cover and filter off. (NO NEED TO REMOVE THE BACKPLATE ). If you look up into the top inside of the throttle body opening, just outside the throttle plate, there's a hole, about 3/8" diameter. If you look up into the hole, there's a plunger in there. That’s the Idle Air Control Valve, which controls idle speed, like an idle speed screw on a carbed engine. If you turn the ignition switch on with the kill switch on, then off again, the plunger will cycle open and closed. Put a rag into the throttle plate opening to catch the gunk and cleaner from going into the throttle body and to keep the cleaner off the engine. Use the start run switch to cycle the plunger on the IAC and spray the cleaner into the hole with the small tube attached to the nozzle of the can, to get pressure into the hole. Keep spraying until the carb cleaner fluid runs out clear. Lots of crap was flushed out. Then re-installed the filter to lessen the chance of backfire setting your garage on fire. Then cranked her up.
KPB46 is offline   Reply With Quote
