Originally Posted by jwkinney
I did not test it today, however I suspect that it is not charging because it cranked rather slowly after that short ride. The dealer checked the voltage with a meter and said several times the stator was good, Im not sure I beleive them
Do you have a factory service manual and are you a little bit mechanically inclined? If so the charging system is easy to check and the procedure is spelled out in the factory service manual. The only tool you will need is a cheap VOM meter (VOM=Volt Ohm Meter). You can get one at radio shack for $20-30 that will work nicely for this.
The testing involves checking for an open in the coils of the stator. Using the lowest OHM setting (x1), place the probes on 2 of the stator wires, it should read less than 1 OHM, basically shorted. Now move one of the leads to the other stator wire, it should read less than 1 OHM also. Now move the other lead (not already moved) to the open wire, and again it should read less than 1 OHM. Basically there are 3 coils and this will test each coil to make sure none of them are open.
Next test, set the meter on a higher OHM scale (x10,000). Now connect one of the probes to engine ground. This is any open piece of metal that is grounded to the engine. Take the other probe and touch each stator wire. The meter should not show a reading. If the meter reads anything, there is a short to ground in the stator and that is not good. Check all 3 stator wires.
The last stator test involves checking the output of the stator while the bike is running. Set the meter on AC Voltage (100 or 200 Volt setting is a good). Then connect the meter up to 2 of the stator wires. Make sure the 3rd wire does not touch anything during the test. With the bike running, the meter should read approximately 20 Volts AC for every 1000 RPM of the engine. There is some leeway in the voltage, exact specs are in the factory service manual. At 1000 RPM it should read 20 VAC and then rev it to 2000 RPM and it should read 40 VAC. No need to rev it any more as that is sufficient indication that the output of that specific coil of the stator is good. Shut the bike off, and move one of the probes to the open wire and test again. Then move the other probe to the currently open wire and test again. This test all 3 coils for proper output.
If it passes all of those test, the stator should not be the problem.
It may should difficult but it only takes about 5 minutes to do all of the above tests and it can be easily done at home without relying on the dealer to get it right.
