Screamin' Eagle Ignition Coil question : V-Twin Forum: Harley Davidson Forums
Old 06-22-2009, 07:29 PM   #1 (permalink)
deprecated wants to know Dino or Syn?
The original (or it least what is on the bike now) ignition coil has three terminals. The SE coil I picked up at the dealership today has only two terminals.... My technical abilities (equivalent to those matching games in kindergarten) have been surpassed.
I'd appreciate any help on how this should be wired. Thanks!
deprecated is offline   Reply With Quote Quick reply to this message
Old 06-23-2009, 07:59 AM   #2 (permalink)
FXRS's Avatar
FXRS wants to know Dino or Syn?
Time for a little research and planning
Sounds like you have a single fire coil installed and you bought a dual fire coil. Take a look at your ignition module to see if you can switch between the two. Then seriously think through what direction you want to go with your ignition system.
FXRS is offline   Reply With Quote Quick reply to this message
