Turn signal module : V-Twin Forum: Harley Davidson Forums
Old 06-23-2008, 12:26 PM   #1 (permalink)
mdazb's Avatar
mdazb wants to know Dino or Syn?
Exclamation Turn signal module
I'm pretty sure my turn sig. module is fryed for the left side. Did the tests per the HD service manual. My question is... is there a aftermarket module that I can install in place of the stock HD module that will plug into the stock harness plug? I'm running LED lights as well. If so would I still need to run equalizers?
Thanks in advance
mdazb is offline   Reply With Quote Quick reply to this message
Old 06-23-2008, 11:44 PM   #2 (permalink)
ASA Lives
Ultra89Rider's Avatar
Ultra89Rider wants to know Dino or Syn?
You can change it, with a lot of work.
The module is a non-serviceable part. It is a HD only part. The only way to get away from the module is to go back to the old turn signal relay. To replace the module, you will need to rewire the turn signal circuit. If you do this, you will loose the self canceling and any other things that come with it. That mean that if you use the relay, it will only flash as long as you hold the button.
If you do change to the relay, go with the electronic relay. It does not require a load equalizer as it flashes the same no mater how many lights are on the circuit.
la'Hom Ho'neH jorDe' vestai-VamPyr
wa'DIch, IKRV Hurgh HaP, Ring of Fire Fleet
Order of the Bat'LetH
"lIgh tlhab"
(Ride Free)
Ultra89Rider is offline   Reply With Quote Quick reply to this message
