SportbikeTrackGearOriginal Bike SpiritsCustom DynamicsMotorcycle.com
BikeBandit
Bike Bandit
Old 05-08-2008, 06:58 PM   #1 (permalink)
mori55's Avatar
mori55 is on a distinguished road
Intermittent problem
I seem to have a intermittent electrical problem. When I'm driving down the road the battery light and check engine light comes on for a couple seconds then goes off. But it's every now and then.
I put the bike on the laptop and it's charging at 13.5 to 14.1 , and of course the battery light never came on then. I wiggled the regulator wires tightened up the grounds , made sure the battery connections were tight.
Wish it wasn't intermittent, it's driving me nuts. Could it be the on off switch? I don't think so , if it was the switch it would be shutting off and it's not , just the battery light followed by check engine for a couple of seconds.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Thundermax ecm and Auto Tune
Samson true dual fishtails.
mori55 is online now   Reply With Quote
Old 05-09-2008, 02:33 PM   #2 (permalink)
mlewis is on a distinguished road
If the event isn’t followed by any operational problem, you have no real clues other than the possibility the ECM is falsely reporting a low battery state.
Fluke, HP and likely others have portable DMM’s with a high/low peak capture capability that you could setup on the bike. With any luck you should get a low reading hit while riding that corresponds to the check light occurrence, if it’s a real event.
If it is real, then you might have an intermittent charging system to contend with.
Good luck!
mlewis is offline   Reply With Quote
Old 05-09-2008, 02:40 PM   #3 (permalink)
rdgzoe's Avatar
rdgzoe is on a distinguished road
Enjoy having a HOG! When my bike gets hot the control panel flash with all kings of lights-Like a Christmas Tree
rdgzoe is offline   Reply With Quote
Old 05-11-2008, 07:13 PM   #4 (permalink)
mori55's Avatar
Changed the voltage regulator , everything is fine now.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
