Old 07-17-2007, 07:42 AM   #1 (permalink)
Woody72's Avatar
Woody72 is on a distinguished road
Advice on wiring up some fans for an oil cooler
I just put an oil cooler on my Ultra, and would like to mount 2 Tornado cooling fans on it for stop and go traffic. While researching them...they come with a 3 or 4 pin adapter. What would be the best way to wire these up? Cut the pins off and just run the wires to an accessory switch? Would I need any kind of fuse or relay or anything. I know absolutely nothing about electrical...so any help would be greatly appreciated!
Woody72 is offline   Reply With Quote
Old 07-18-2007, 11:31 AM   #2 (permalink)
Woody72's Avatar
No takers huh?
Old 07-18-2007, 11:35 AM   #3 (permalink)
PR3VS56's Avatar
PR3VS56 is on a distinguished road
I'm trying to picture it...................
'09 FLTRI, Vivid Black, ABS.
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Redline 20W50HD
'05 FLTRI, totaled 10/17/08.
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is offline   Reply With Quote
Old 07-18-2007, 11:39 AM   #4 (permalink)
jammerx is on a distinguished road
Electrically you should be able to wire them direct to the acc switch, I would look in the manual to see what protection feeds that acc switch circuit. You may want to fuse them. They should only be .75 to 1 amp a piece. I saw a write on the internet a while back, about somebody who did the same thing. Google it. Here you go...
http://www.bamph.com/rmh/oilfan.htm
jammerx is offline   Reply With Quote
Old 07-18-2007, 12:05 PM   #5 (permalink)
Woody72's Avatar
I'll check that out...thanks!
Old 07-22-2007, 01:49 PM   #6 (permalink)
Woody72's Avatar
I checked out the link...but it doesn't say anything about how to wire it up. Anyone?
Old 07-22-2007, 01:57 PM   #7 (permalink)
Total Nutcase
JamieWG's Avatar
JamieWG is on a distinguished road
I've never done it before, so take this for what it's worth. They are just little electrical motors. You'll need a power and a ground wire, a switch and a fuse. It's no different than wiring up a car radio. Run it off the accessory link from the bike. Def use a fuse, because those little computer fans are known to seize up once in a while, plus they will probably be getting wet.. Should be easy to set up.
JamieWG is offline   Reply With Quote
Old 07-26-2007, 10:20 AM   #8 (permalink)
rides99fatboy's Avatar
rides99fatboy is on a distinguished road
Those fans look like what is typically used in a computer system. The extra wires are used for measuring the RPM of the fan so the system board can report on fan failures. Not needed for your application. I have some that include in addition a thermal sensor to switch the fan on when the ambient temp reaches a certain point. (4 wires)
rides99fatboy is offline   Reply With Quote
