More Kuryakyn Panacea Issues
I have a 1994 Heritage Softail. I added Kuryakyn front LEDs about a month ago and wired in the load equalizer. No problems there, worked perfectly.
The other day I added the Kuryakyn Panacea LED Tail Light and Turn Signals. Had to wire in the 12-pin wiring harness adapter for pre-96 Softails. Plugged in the Kuryakyn 'Hot Bus' module and it worked perfectly for about a day, then I noticed the rear turn signals would not work in any mode (run, turn, or stop). So, I put the stock bulbs back in, and I had no right signals at all. Left side worked.
Oddly, the turn signal in the Panacea Tail Light would still operate normally, even with stock bulbs in the turn signal housings. And the front right LED signals would work also.
Never did get the right rear signal to work.
Called Kuryakyn and they said it sounded like something on the bike was bad, not their 'Hot Bus', which made sense because the right signal wouldn't work even with the Panacea stuff removed from the bike.
Any chance the stock Harley Turn Signal Module went bad? The left side signals still work. Anybody else had trouble with the Panacea stuff on pre-96 Softails?
Skull scratching here.....
