nevermind... I just figured out why I couldn't find that part number... you're in australia and have one of them there foreign Harley speedos in KPH! 67197-99a is the larger Softail/Road King speedo in KPH.
The connector is a 12 position Deutsch DTM (Mini DT series).
you can order a complete one from
www.deutschconnector.com. It would be the 12 position DTM "BLACK KEY POSITION", p/n: DTM06-12SB (comes with stamped sockets that you can crimp with a normal pair of good barrel connector crimpers....
Or, you can order the parts from H-D:
74119-98BK - connector housing 12-way (1)
74152-98 - connector secondary lock 12-way (1)
74191-98 - terminals (12)
Here's your pin out for the speedo:
1 - Accessory power (12v+)
2 - trip switch
3 -
4 - check engine light
5 - security light
6 -
7 - speed sensor ground (ground to VSS. Black on VSS)
8 - speed sensor power (12v+ to VSS. Red on VSS)
9 - speed sensor signal input (VSS Output. White on VSS)
10 - GROUND
11 - trip switch
12 - speed output (for turn signal module)
