Motorcycle.comSportbikeTrackGearDan Vance Racing
Leslie Kay'sFuel MotoStainless Ride Specialty Accessories
CycleGear.com
Old 02-01-2007, 02:19 PM   #1 (permalink)
whittlebeast is on a distinguished road
Harley ECU pinout
I am going to do a quick dis-connect MegaSquirt (MicroSquirt) install that will work on a factory Harley EFI. Does anyone know if the ECU pin out and color codes on Harley is universal?
Do all ECU's use a Packard 100w
On a 2007 Sportster it's
1_____n/a____________
2____gn/o_____system relay
3_____n/a____________
4_____n/a____________
5____lgn/v____serial data
6____pk/y_____engine temp
7____lgn/y____IAT
8____pk/o_____front O2
9_____n/a____________
10____bk_____system ground (see 28
11___y/be____rear coil ground
12___bk______ckp-
13___w/bk____12v Switched power in
14___r/w_____5 v ref to VSS, TPS, MAP and engine temp sensors
15____n/a____________
16____n/a____________
17____bk/o____IAC (A) high
18___bk/pk____IAC (B) low
19___gn/gy____rear injector ground
20____n/a____________
21____w/y____front injector ground
22____n/a____________
23___pk/gn____rear O2
24___gy/v_____TPS
25___v/w______MAP
26___bk/w_____sensor ground (5v sensors)
27_____n/a____________
28___bk_______system ground (see 10)
29___be/o_____front coil ground
30___r_ckp+
31___be/gy____12v battery constent hot
32_____n/a____________
33___bk/be____VSS
34_____n/a____________
35___be/gn____IAC (A) low
36___bn/r_____IAC (B) high
AW
whittlebeast is offline   Reply With Quote
Old 02-02-2007, 09:13 AM   #2 (permalink)
Does anyone have the Electrical diagnostics manual for any other factory Harley other than a Sportster? At $60 each I hate to have to purchase all of them.
AW
Old 02-02-2007, 01:49 PM   #3 (permalink)
07softayl is on a distinguished road
Hi AW.
I just received my diagnostic manual for my 07 softail. The service manual also has wiring diagrams in it that could answer your question. I will check later on to see if they are the same as for the sportser.
cheers
Mick
07softayl is offline   Reply With Quote
Old 02-02-2007, 02:49 PM   #4 (permalink)
Wink
On a 2007 Softail (International version)
1_____V/BE____Exhaust Feedback
3_____N/A___Tach Output (no tach on softail)
4____gn/o_____system relay
7____lgn/y____IAT
10____bk/gn_____system ground (see 28
12___bk______ckp-
20____v/o_____Exhaust command
22____GY/O___Intake solenoid
24___gy/v_____TPS
25___v/w______MAP
27_____gy/be__Ion Sense
28___bk/gn_______system ground (see 10)
30___r________ckp+
33___w/gn____VSS
As far as the plug, it is a packard 100W.
hope this helps
regards
Mick
Old 02-02-2007, 03:03 PM   #5 (permalink)
Any clue what those are?
AW
Old 02-02-2007, 03:14 PM   #6 (permalink)
Enjoying life
nc-renegade's Avatar
nc-renegade is on a distinguished road
AW
Just guessing, but that might be for the European bikes. They have something extra on the exhaust if my memory serves me correctly.
nc-renegade is offline   Reply With Quote
Old 02-02-2007, 03:30 PM   #7 (permalink)
We are so lucky in the international world that we have been blessed with active intake and exhaust.
These units operate to control "performance" (read noise) when you are riding.
The exhaust items (1 & 20) are servo motor control and feedback signals. The servo motor shuts a flap one exhaust pipe that redirects all the gases through the other pipe ( which has a smaller dia. outlet).
The active intake solenoid (22) actually drives a solenoid that operates a flap in the intake to allow more air in at 70kph+ @ 50% throttle +.
you gotta love the marketing spin that is put on this stuff. . Enhances performance......
Mick
[IMG] code is Off
