Stage1 that bad?
I know the 07's run lean, probably even with the "0903 Smoothing" setup in them, but is a basic dealer Stage1 really that bad / waste of money?
Modern engines (cars) seem to get good numbers without being too rich, so although maybe not ideal would a dealer Stage1 be good enough for the money to have an 07 run well without excessive heat? Meaning just real world dependable without seeking a certain Dyno number.
The HD website shows the Stage1 for the 96" Dyno with about 85 lbs. tq. @ rear wheel from 2,500 to 4,000 rpm's. That seems decent, if it's correct, if it also keeps you away from excessive heat.
07 FLHRS Cobalt Blue:Stage1 Download, Andrews 26H Cams, V&H FuelPak, Cobra Slip-Ons, K&N 3909, HD Oil Cooler, WILD1 Chubbys, Turn sig. relocate, Braided cables, Metzler 880's, Floating Rotors, IDS.
