Cycle Gear
Old 08-26-2006, 03:28 PM   #1 (permalink)
mori55's Avatar
mori55 is on a distinguished road
Check Engine Light
When ever i load a sert map, every thing seems fine until i take a ride. After a few minutes the chek engine light comes on. Any ideas?
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Thundermax ecm and Auto Tune
Samson true dual fishtails.
mori55 is offline   Reply With Quote
Old 08-26-2006, 04:46 PM   #2 (permalink)
mori55's Avatar
Originally Posted by SEDELUXE
you have some codes stored use the sert to clear them
I looked in the insrtuctions and couldn't find anything on it.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Old 08-26-2006, 05:20 PM   #3 (permalink)
Total Nutcase
JamieWG's Avatar
JamieWG is on a distinguished road
Use data mode to check DTCs and to clear them. DTC codes are checked, reset, and recorded using the Data Recording forms’ ECM Diagnostic Codes window.
Checking DTC codes:
To check for codes, press the Get DTC’s button; Data Mode will interrogate the ECM for all possible codes and report back with a list of all possible codes and whether they are set or not.
Clearing DTC codes:
To clear all set DTC codes, press the Clear DTC’s button. The codes will be cleared within a few seconds. After clearing codes, you can immediately check their status using the Get DTC’s button to verify their new values
JamieWG is offline   Reply With Quote
Old 08-26-2006, 09:07 PM   #4 (permalink)
mori55's Avatar
I got the codes there were 44 of them 1 would be voltage high one would voltage low , one would be one way and one would be the complete opposite.
I cleared them took a ride light came on same thing. anyone have any idea whats going on?
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Old 08-26-2006, 10:36 PM   #5 (permalink)
Total Nutcase
JamieWG's Avatar
Wild assed guess? Voltage regulator.. have you done any mods to anything electrical on the bike? Any other symptoms.. anything weird happening?
[IMG] code is Off
