Fuel MotoPowerstar SparkplugsOriginal Bike SpiritsProCharger.comSportbikeTrackGear
Old 08-25-2006, 10:00 PM   #1 (permalink)
mori55's Avatar
mori55 is on a distinguished road
sert ????
I just put a sert on my bike today and i'm having problems loading maps that i saved from here and gmr. Once i try to download the map to the ecu it says i have the wrong calibration # and ecu pin? any ideas?
It hooked up fine, mated fine ,reads the ecu, the only thing i can,t do is load the maps from my pc . I can open the maps on the tuning page but thats it.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Thundermax ecm and Auto Tune
Samson true dual fishtails.
mori55 is offline   Reply With Quote
Old 08-26-2006, 10:12 AM   #2 (permalink)
mori55's Avatar
Originally Posted by SEDELUXE
Mori can you load any map. or is it just the maps from gmr or vtf ?
are the maps loaded in my 2005-2006 calibrations?
I haven't tried the canned maps yet. just the gmr and here .
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Old 08-26-2006, 11:16 AM   #3 (permalink)
ovanay elinquentday
GPO03FatBoy is on a distinguished road
When you read your ECM data, what is your ECM part #? Check to make sure this is the same as the ECM # in the map data. Also, no matter what the file name is, for your 05 check to make sure the Cal ID of the map starts with 127. If not, the map is for a different year bike and you would have to manually convert the map you want to load to a map table with a proper part #, in order to use the data.
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
GPO03FatBoy is offline   Reply With Quote
Old 08-26-2006, 01:10 PM   #4 (permalink)
mori55's Avatar
Thats what the problem it says ecm # isn't the same and that the cal id is different. how do i get to work?
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Old 08-26-2006, 01:43 PM   #5 (permalink)
ovanay elinquentday
What isyour ECM #?? and what ECM and part #'s are listed in the map?
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
Old 08-26-2006, 02:29 PM   #6 (permalink)
mori55's Avatar
Ecm is 321498-05 cal id is `127hn005134. From what i'm starting to understand is each map has to start with 127, correct? With my build what would be a good canned map to start with? If i see a map on gmr's site that looks close but has the wrong id how do i change it?
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Old 08-26-2006, 02:41 PM   #7 (permalink)
ovanay elinquentday
Pick any 127........ map that you like as a base map. If you are finnicky, you might want to pick one that has the factory description which most closely resembles your build, but it really doesn't matter. Open the map that works with your build in one window. Open the map that you want to use the data from in another window. Then, table by table, block copy the data that you want to use, from the data map to the map that works with your bike. Once you have everything copied over, save your newly created map to a new file name. The file name can be anything, it's the cal id that your ECM will look at.
You may also want to edit the last three digits of the cal id for your new map to be something different than the 000 of the original map. If this is your first new map then you could use 100 in the last three and make any later edits 101, 102, 103,....
My personal opinion though is that you would be better off starting with a map created for your year bike, even if it is a stock HD map, and take it to a tuner to get it set up for your build. Good luck!
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
Old 08-26-2006, 02:43 PM   #8 (permalink)
ovanay elinquentday
One other thought, if you do convert a map, check the RPM values in your tables. Not all the maps use the same rpm values in the fuel tables. Since the maps won't be built for your bike anyways it shouldn't be too critical, you just need to be aware of any differences as you transfer data.
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
Old 08-26-2006, 02:50 PM   #9 (permalink)
mori55's Avatar
One more question whenever i load a map , after i drive it the check engine light comes on.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
[IMG] code is Off
