Dan Vance Racing
Old 08-12-2006, 09:03 AM   #1 (permalink)
Steve In Iraq is on a distinguished road
Is a HD ECM Flash required with PC III/USB
Hi all
Ok so I am going to build a GMR 98" and add a PC III to make it work,, Do I need to have the SE Stage I or II ECM flash or will the PC III be able to compensate enough?? It will be a NEW PC III so should have the REV extender like the SE Stage I&II Flashes.
Do not want to sound too cheap but 150$ for a flash = new Ness Big Sucker
Thank for the info
Steve In Iraq is offline   Reply With Quote
Old 08-12-2006, 09:15 AM   #2 (permalink)
No, but some people do it as a back-up should the PC111 fail.
Haven't heard of them failing tho for several years.
nvsteve is online now   Reply With Quote
Old 08-12-2006, 09:24 AM   #3 (permalink)
GareyD is on a distinguished road
It's kinda like wearing a belt and suspenders....
The only reason to get the HD download is in case the PCIII was to crap out you could take it out of the line and ride home on the download without being too lean....I've installed around 300 PowerCommanders and have only had one of the very first PCII's go bad...All 4 of our personal bikes at the shop are running the stock ECM, no download....
My
GareyD is offline   Reply With Quote
Old 08-12-2006, 10:12 AM   #4 (permalink)
Doofhead
Just saw one fail last week on a RK. It would start for 2 or 3 secs tne die. It had came loose under the left side cover and was cut through by the belt. When we first hooked up the Scanalyzer, we saw the Baro reading going low and then into Default. Traced it to the dead PC. Having a map in the ECM that the bike will run on without hurting itself just makes good sense. Better yet, use a SERT and you don't have to worry about the PC failing.
Totenkopf is offline   Reply With Quote
Old 08-12-2006, 10:36 AM   #5 (permalink)
Hellbound Train
csoday's Avatar
For piece of mind, get a SERT. One less thing to fuk up and a much better tune.
Chuck Soday
GO FAST
'03 FXSTBI 103" Stroker
112 hp -- 121 tq
100% S.E.
My V Twin Gallery
Old 08-12-2006, 12:16 PM   #6 (permalink)
Lickskillet is on a distinguished road
Steve,
First, Thank You For Serving Our Country... Now,,,, YOU DONT NEED A SERT.... Your PCIII will do just fine and the flash is a waste of money. HD makes a ton of money in five minutes flashing ECMs...
Ride On,,, and ENJOY
2006 Vivid Black Road King Classic
Rinehart True Duals
Arlen Ness Big Sucker
Dyno Jet PCIII
"Theres Plenty Of Room For All Of God's Creatures,,, Right Next To The Mashed Potatoes"
Lickskillet is offline   Reply With Quote
Old 08-12-2006, 01:29 PM   #7 (permalink)
Bobby B. is on a distinguished road
I'm considering trading my PowerCommander for a Race tuner. Is there a map available for an '05 Road King, stage 1 with Bassani reverse magaphone and a true dual setup.
If there is a good startup map, It'll make my decision a lot easier.
Bobby B.
Bobby B. is offline   Reply With Quote
Old 08-12-2006, 06:34 PM   #8 (permalink)
DR EVO
otterbob is on a distinguished road
Used to be you would need the stage 1 reflash to get the higher rev limit, but now you can do it with the power commander. Your wallet and dyno tuner will love you if you go with the power commander. The pc is not restricted to one bike, you can take your power commander with you if you sell your bike, it takes less time to dyno tune, and you can back up the custom map for your own use. the power commander allows for a live tune of your bike without the need to poke and hope like the sert. Yes the sert is a more robust tuner, but you dont need it.
2008 FLSTC Goodbye to the oil chugging, piston slapping Rev performance Fatboy!
otterbob is offline   Reply With Quote
Old 08-12-2006, 09:16 PM   #9 (permalink)
Fuel SYS ENG
Vetteman is on a distinguished road
Power Commanders fail more often then we give them credit. I often get them going again with a master reset. It just makes plain sense to flash the ECU and not add a piggyback system to a HD. Enjoy your SERT while you can.............
DOT has ensured MOCO won't be offering true performance products for our bikes in the very near future.
Cheers,
Frank
Vetteman is offline   Reply With Quote
Old 08-12-2006, 10:40 PM   #10 (permalink)
Hellbound Train
csoday's Avatar
What are you basing that statement on?
Chuck Soday
GO FAST
112 hp -- 121 tq
100% S.E.
My V Twin Gallery
Old 08-12-2006, 11:08 PM   #11 (permalink)
Cheers,
Frank
Huh??.......
Old 08-13-2006, 12:13 AM   #12 (permalink)
wuudbee is on a distinguished road
The MoCo will be discontinuing the SE Calibration cartridge but performance calibration will still be availabel.
wuudbee is offline   Reply With Quote
Old 08-13-2006, 01:24 PM   #13 (permalink)
I cant believe some of the crap that is said on here sometimes. Sheesh... There truly are some ding dongs or at least ding dong statements made....
I better just shut up or I will get myself in trouble.... Good luck with whatever you decide to do...
Rinehart True Duals
Dyno Jet PCIII
Old 08-13-2006, 01:55 PM   #14 (permalink)
Fuel SYS ENG
You can believe what you want! I've read the letters.
Cheers,
Frank
Old 08-13-2006, 02:06 PM   #15 (permalink)
Hellbound Train
csoday's Avatar
Cheers,
Frank
Is this one of the letters?
Screamin’ Eagle Calibration Cartridges
Purpose:
The purpose of this bulletin is to:
1) Announce that all Screamin’ Eagle Calibration cartridges will be discontinued at the beginning
of the 2007 Model Year.
2) Clarify that performance calibrations will still be available from Harley-Davidson.
3) Communicate where to get calibrations in the future.
Calibration cartridges will be discontinued from the Screamin’ Eagle product line, starting in Mid-
July, 2006. As inventory is depleted on each cartridge part number, they will become obsolete
and will no longer be sold. We expect that some cartridges will become obsolete during the
month of July, others may have inventory available for approximately 1 to 2 months.
Legal as well as Race Calibrations will continue to be available via the following delivery methods:
I. Digital Technician
Performance Legal:
 1995 - 2007 model year calibrations available in Digital Technician Phase 19 software to: US,
CAN, Mexico, Bahamas, Dom Republic, Guam, Puerto Rico, Virgin Islands.
Note: 2007 model year calibrations are not in Digital Technician Phase 19 for countries outside
of specified markets
 1995 - 2006 model years will be made available to countries outside specified markets (except
France), but are considered to be “Race” calibrations in those markets.
Race:
 2006 model year calibrations are available in Digital Technician Phase 19 software to all
markets except France
 2005 – 1995 model years calibrations are targeted to be in Digital Technician by fall 2006.
o Note: 2007 and future Race calibrations will not be available on Digital Technician.
I
I. EFI Race Tuner
 Contains 1997-2007 model year RACE calibrations, see the Screamin’ Eagle Pro Catalog for
current part number.
The billing process for chargeable calibrations from Digital Technician is outlined on the following
page.
Questions
Please contact Technical Services with any concerns regarding installation or product quality.
Direct all other questions to your SPOC representative.
890 07-20-2006
2
Digital Technician – Chargeable Calibration Billing Process
The Following information applies to calibration downloads done through Digital Technician which
are considered “Chargeable Calibrations.” Chargeable calibrations include all performance
calibrations (Performance – Legal and Performance – Race) as well as OE “stock”
calibrations for CVO models where available.
Typical sequence of events for Digital Technician Calibration billing process:
Step 1: Technician performs chargeable calibration download from Digital Technician.
Step 2: Digital Technician performs an Auto-Sync.
Step 3: Harley-Davidson generates invoices to dealer or distributor.
Note: Distributors are invoiced directly for downloads performed by their dealers. The invoice
indicates the Dealer Number and Digital Technician Unit ID to identify the unit that performed the
download.
I
nvoices provide the following information for chargeable downloads performed from the following
REFLASH categories in Digital Technician:
REFLASH
Categories
OE (for CVO models)
Performance – Legal
Performance - Race
Calibration Number 34232-06 /DT 34232-06 /DT
Calibration Description: CART ’06 TOURING 1450 ST 1
DIG TECH
1 DIG TECH
Dealer Number: Flash update for dealer: xxxx Flash update for dealer: xxxx
VIN: 1HD1FCW176Y123456 blank
Date / Time Flashed: 6/29/06 4:22:50 PM 6/30/06 10:28:35 AM
Unit ID: xxxxxx xxxxxx
Note: Performance-Race downloads do not have VIN information on Invoice.
Note: Dealers can verify invoices against “Reflash History” on their Digital Technician.
Note: Performance – Race calibrations will only display a partial VIN in the Reflash History logs
on the dealer’s Digital Technician unit.
Chuck Soday
GO FAST
112 hp -- 121 tq
100% S.E.
My V Twin Gallery
[IMG] code is Off
