07 closed loop perf mod question
I currently own an '04 FLHTi with V&H True Duals, SE Race Fueler & Stage I air filter... I like the bike & will most likely keep it.
My question is in ref to the new '07 96ci bikes. My very limited knowledge of efi tells me that a closed loop system adjusts itself automatically to conditions rather than the efi system in my '04 which requires the use of the race fueler to adjust for the true duals, etc... is this correct? If so, does that mean you could change the exhaust out on an '07 (using an O2 sensor in the pipes) without using a race fueler or similar device?
I guess what I am trying to determine is how easy/difficult would it be to upgrade the '07 to Ture Duals + stage 1 air filter & what kind of added performance could I expect from these basic mods. I prefer the tru duals over stock due to the heat the rear cylinder throws off with the stock pipes.
Steve
2009 Road King
