Custom DynamicsOriginal Bike SpiritsProCharger.comLeslie Kay'sDiamond Bar ChoppersCycleGear.comDan Vance RacingSportbikeTrackGear
Stainless Ride Specialty Accessories
CycleGear.com
Old 04-27-2006, 01:24 PM   #1 (permalink)
tivonkaden2 is on a distinguished road
Pros and Cons of Power Commander vs Race Tuner
I ride a 2005 Heritage Softail EFI. I have a stage 1 kit with Screaming Eagle II
slip-ons and a stage 1 download. I want to put a 2 into 1 pipe (either VH Pro Pipe HS or a Bassani
Road Rage). The Harley dealer recommends the race tuner and the Local
Harley Drag shop recommends the Power Commander. Is one that much
better than the other? One Shop or the other will do the work.
tivonkaden2 is offline   Reply With Quote
Old 04-27-2006, 01:33 PM   #2 (permalink)
XLIII
MegaGlide's Avatar
MegaGlide is on a distinguished road
First, who's gonna tune it and what do they do their best work with?
Dave
I mock, therefore I am.
MegaGlide is offline   Reply With Quote
Old 04-27-2006, 02:09 PM   #3 (permalink)
SFTL-1's Avatar
SFTL-1 is on a distinguished road
Agreed, the SERT won't do you any good if your tuner in not competent with it and the same goes with the PC.
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
SE 257, HTCC Heads & Intake
Hooker Troublemaker Pipes
SFTL-1 is offline   Reply With Quote
Old 04-27-2006, 02:10 PM   #4 (permalink)
Who's going to work on it
Either the Harley Dealer or the Drag shop will do the work
Old 04-27-2006, 02:43 PM   #5 (permalink)
BryanL's Avatar
BryanL is on a distinguished road
If you go to Latus, they prefer the SERT. I think Paradise prefers the PCIII. Does the Drag shop have a dyno? If not, you may be paying for a lot of guess work. Mike Stedman (or Stegman) is the tuner for Latus, He's one of the best in town. Unfortunately he's going on the road this summer with the race team, but he's been training another guy on the dyno for quite awhile.
BryanL is offline   Reply With Quote
Old 04-27-2006, 03:23 PM   #6 (permalink)
Fire4Effect's Avatar
Fire4Effect is on a distinguished road
Check your PM please.
Fire4Effect - Eatin one bug at a time...
2002 FXSTD - 106" 10 -1 comp / S&S heads / Mikuni HSR-42 Carb / 570G cams / DTT Ign / Feuling oil pump / V&H longs
Fire4Effect is offline   Reply With Quote
Old 04-28-2006, 01:44 PM   #7 (permalink)
OrangeTJ is on a distinguished road
tuning
I always thought that the advantage of the PCIII was that you didn't really have to futz with having the bike dyno tuned, since they have so many canned maps available for different combinations of parts. Will a bike run good with one of the PCIII canned maps for a relatively stock build (i.e. aircleaner & pipes) or do you really need to get it dyno tuned?
OrangeTJ is offline   Reply With Quote
Old 04-28-2006, 02:03 PM   #8 (permalink)
DynoJet has maps available for download on their website for most builds now. Most of the time those maps are very close and often there is no "need" for a dyno tune for a Stage-1. I use the word "need" because in the hands of a competent tuner you will usually eek out a bit more HP/TQ if you DO get it dyno-tuned though.
As you add more (heads, cams, etc) the "need" for a dyno tune increases.
It is only 1 - 2 hours of dyno-time (so here that would be $90 to $180) for a tune and custom map made for your bike under your area conditions (altitude, etc.) I believe in that even with a stage 1 because I am a perfectionist.
Will a typical Stage 1 run well with a canned PCIII map? Normally - YES.
How do you know what "good enough" is without paying for a custom map? Read the plugs after 500 miles, no "popping" or missing, and monitor your fuel mileage. Those will tell you if your canned map is good enough.
[IMG] code is Off
