Diamond Bar ChoppersPowerstar SparkplugsFuel MotoDan Vance RacingCustom DynamicsOriginal Bike SpiritsStainless Ride Specialty Accessories
GoFreeCreditReport
Old 09-17-2004, 11:26 PM   #1 (permalink)
03classic is on a distinguished road
Looking for map mods to M807-010 to cure decel pop
just trying to eliminate that annoying pop w/o spending big money on a dyno tune. thanks.
03classic is offline   Reply With Quote
Old 09-18-2004, 01:03 PM   #2 (permalink)
GRock is on a distinguished road
03,
You are running a bit lean and you need to add fuel to the 0 and 2% throttle position columns from 500 to 4000 RPM. Increase the number in those cells by 5 and see where you are after a ride. If it's gone you are good, if it's just better keep adding a little fuel into each cell until it disappears. Keep in mind that depending on the pipes, you may not be able to eliminate popping completely if you suffer from extreme reversion. Also, be sure to save the map that is already loaded in it's original form and save the new map as it's own separate file. (the one with the changes.)
43
GRock is offline   Reply With Quote
[IMG] code is Off
