American Side Road CycleDan Vance RacingMotorcycle-CommunicationBub EnterprisesProCharger.comLeslie Kay'sCustom DynamicsRRcycles.comAdvanstarMotorcycleShowsJardineProducts.com
Old 11-05-2009, 03:09 PM   #1 (permalink)
allaco is on a distinguished road
andrews 26 cams pc 3 map
I am looking for a map for a build with andrews cams. I did not see anything on the power commander site with the cams I have. Any help would be appreciated thank you
2001 flhrci (magneeti-marelli efi)
se air cleaner
rinehart 2 into 1 exhaust
andrews 26 cams
pc 3 usb
allaco is offline   Reply With Quote
Old 11-05-2009, 05:54 PM   #2 (permalink)
Site Sponsor
Is the ECU stock or Stage 1?
Old 11-05-2009, 06:21 PM   #3 (permalink)
stock ecu ,and engine except for the cams thank you
Old 11-06-2009, 11:18 AM   #4 (permalink)
Site Sponsor
Here is a starter map. Give this a try and let me know how it works for you.
Old 11-06-2009, 03:44 PM   #5 (permalink)
I will try that this weekend ,thank you. will let you know how it runs enjoy your trip Alan
Old 11-10-2009, 03:37 PM   #6 (permalink)
andrews 26 cams
I installed the map and ran it this weekend. It ran pretty good. The only issues i had was a slight stumbling between 2600-2800 rpm at a steady run at about 20-30% throttle.This was not constant just intermittently.the exhaust note sounds a little hollow but it is a different pipe than I had. I might just need to get used to it. Any suggestions Thank you. Alan
Old 11-11-2009, 06:20 AM   #7 (permalink)
Avatars by 8-Ball
Jonas's Avatar
Jonas is on a distinguished road
No help on the map, but just a couple comments.
I went with the 26 cam on my 2004 RoadKing 88". I saw a "BIG Difference". Dyno'd 90ftpounds of tourque and 82hp.
One problem I had after the dyno tune was said and done(I bought the TTS Module for tuning)
I had to change the Wild Pig 1.75" baffles to 2.0" baffles(stock exhaust). The problem I had was. If I took off balls to the wall, the bike would really loose power around 90mph. Doc suggested the 2" Baffles and a 5% change across the board to the tune(can't remember exactly what). Problem solved and it feels like there is a increase in power across the board. So I got to believe it is somewhere above the 82/90 numbers now.
Our setups are very close besides the exhaust.
Jonas
82-88 USMC
2004 Road King
1981 FLH
Jonas is offline   Reply With Quote
Old 11-13-2009, 08:38 AM   #8 (permalink)
Thanks I hope I hope I get somewhere near those numbers. So far I reallly like what the cams have done for the bike. I had true duals but the 2 into 1 is starting to grow on me
Old 11-18-2009, 12:47 PM   #9 (permalink)
Site Sponsor
Try this and see if it is any better in that range
[IMG] code is Off
