Fuel MotoBub EnterprisesSportbikeTrackGear
American Side Road CycleMBO EnterprisesJardineProducts.comLeslie Kay'sCycleGear.comJekillandHyde.euProCharger.com
Bike Bandit
Old 10-28-2009, 11:49 PM   #1 (permalink)
Murlsquirl is on a distinguished road
PCV map request for DynoJet
2009 Night Train (CA bike)
V&H Pro Pipe BP
SE Heavy Breather
Stage 1 download
I was thinking of trying 004-005 (Thunder Header 2into/SE Air Filter). That is the only one that really comes close because the one for my pipe says "stock ecm". If you could email the map to murlsquirl@yahoo.com I would appreciate it. Thanks.
Murlsquirl is offline   Reply With Quote
Old 10-29-2009, 11:05 AM   #2 (permalink)
Site Sponsor
The Stage 1 download will be fine. In our testing it did virtually nothing to the fuel curve and was mainly to increase the rev limit to 6200. You can use the "stock ECM" map with your setup.
Old 10-29-2009, 03:49 PM   #3 (permalink)
I changed the map and I will give it a run tonight. I will let you know how it works. Thanks for the quick reply.
Old 10-30-2009, 08:43 PM   #4 (permalink)
Got everything installed today and ran it through a whole tank of gas. Still got almost 200 to the tank and it ran great. Not a hiccup on decel and between the PCV and the new pipe I am loving it. I think it can run better, maybe a dyno. The only thing was maybe a little high idle, not bad though. Thanks alot.
Think I should try to tweak anything or leave it?
Old 11-02-2009, 12:14 PM   #5 (permalink)
Site Sponsor
Sounds like it is working as it should. You can try changing all the numbers in the 0% column to "0" if the slightly high idle is an issue (make sure to do both cylinders).
Old 11-04-2009, 12:50 AM   #6 (permalink)
I think I will keep it as is for now. I will remember that if it becomes an issue. Thanks alot for the help.
[IMG] code is Off
