PC III USB Map Request...
I have a "stock" 2001 FLTRSEI2 (Screaming Eagle Road Glide) From the factory it came with 95" and 203 cams. Mufflers are stock and the air cleaner is stock. No dealer has been able to tell me if it is factory stage 1 download or not. The air cleaner has 2 inlets, 1 forward and 1 rear vice the stock one which only has 1 inlet. The slip on's are stock 80db but different than the stock FLT mufflers. Now I have the PC III on there and it runs better but a little flat. The exhaust note is not crisp. I am running the M802-355. I saw some of the maps for the PC II that are for SE 95" factory but I thought I read you cant use those maps so I didnt try. Anyone come across this? Thanks in advance.
