No, you cannot directly load the PCIII maps into a PCV. You will need to open the PCIII map using the PCIII software. Then, open a zero map for a 2009 Touring bike in the PCV software.
You will then have to "copy and paste" the values from the PCIII map into the PCV software. You will also notice that there is an additional TP coulmn of 15% in the PCV software that is not in the PCIII software. You are going to have to manually interpolate (blend) those values. Going across the RPM rows, take the 10% value and the 20% value and add them together and then divide by 2. Put that value in the 15% column for each RPM.
