ProCharger.comRRcycles.comMotorcycle.com
Pro PadAdvanstarMotorcycleShowsMotorcycle-CommunicationLeslie Kay'sJardineProducts.comCycleGear.comMBO Enterprises
Old 09-28-2009, 10:56 PM   #1 (permalink)
'06 FLHT
makoscg is on a distinguished road
PC Map Request for 06 FLHT
I'm looking for a PC map for:
'06 FLHT
Rinehart Slip-ons
Ness high flow filter
(everything else stock)
I have a Power Commander 3 USB #807-511.
Currently running m807-218, pipes are turning red after 3-5 min of idle time.
Thanks for any help.
makoscg is offline   Reply With Quote
Old 09-29-2009, 11:25 AM   #2 (permalink)
Site Sponsor
Your only issue is that the pipes are glowing at idle? Other than that the bike runs well?
Old 09-29-2009, 11:31 AM   #3 (permalink)
'06 FLHT
I just installed the pipes, filter and PC. I noticed the pipes glowing and was concerned. I haven't take the bike for a ride yet, didn't want to create any problems (not being familar with the EFI). Recommendations?
Old 09-29-2009, 11:38 AM   #4 (permalink)
Site Sponsor
Are you just talking about the first couple of inches of the headpipes glowing a dull red or much further down? These are still stock headpipes correct?
Old 09-29-2009, 11:41 AM   #5 (permalink)
'06 FLHT
They are stock headers. The get glow down to the floorboards.
Old 09-29-2009, 11:43 AM   #6 (permalink)
'06 FLHT
I was considering trying m807-212 map file. It appears to be a bit richer?
Old 09-29-2009, 12:00 PM   #7 (permalink)
Site Sponsor
I have a difficult time beliveing that the pipes are glowing that much just from sitting at idle. Even without a Power Commander this should not be the case. Are you holding the bike at a higher than normal idle?
Are you sure the exhaust gaskets are sealed?
Old 09-29-2009, 12:05 PM   #8 (permalink)
'06 FLHT
I haven't taken the headers off. The gaskets are factory installed (approx. 7500 miles on them). As for the idle, this is just walking away from the bike and coming back after a couple of minutes. Not touching the throttle.
I've seen this problem once before with a friend of mine. Once we got the correct map, the problem went away. I'm hoping that this is the case once again.
Old 09-29-2009, 03:24 PM   #9 (permalink)
Site Sponsor
First, make sure that the Throttle % in the software reads "0" when the bike is warm and at idle.
What is the current warm idle speed?
Load map M807-000 (all zeros) and see if the problem is better or worse. Let me know and I can make adjustments from there.
Old 09-29-2009, 04:07 PM   #10 (permalink)
'06 FLHT
I will check this later this evening and get back to you. Thanks.
Old 09-29-2009, 06:02 PM   #11 (permalink)
'06 FLHT
I loaded the zero map, the pipes still glowed red. The throttle is at 5% and idle speed is 1000 rmp when warm.
Old 09-29-2009, 07:35 PM   #12 (permalink)
Site Sponsor
You need to reset the TP% to read 0% when the bike is at idle. You can watch a video tutorial on how to do this at:
http://www.powercommander.com/powerc...20Throttle.swf
Was teh glowing any more or less with the zero map? It should have been one or the other.
Old 09-29-2009, 09:05 PM   #13 (permalink)
'06 FLHT
The glowing was less.
Old 09-30-2009, 10:56 AM   #14 (permalink)
Site Sponsor
That is interesting as the "zero map" has no fuel added at idle and the previous map did. I think there may be some other problem that we are missing. Just adding slip ons should not have induced the problem you describe.
Old 09-30-2009, 03:48 PM   #15 (permalink)
'06 FLHT
I decided to verify the stock configuration. I put the original OEM mufflers and air filter back on the bike to check for the glowing. I do not having any glowing withthe OEM configuration. I left the PC on the bike with the zero map. Not sure if this help in troubleshooting or adds more complexity. Any thoughts? If I didn't have the glowing problem, what map would you suggest for my "attempted " configuration?
[IMG] code is Off
