American Side Road CycleBub EnterprisesPro PadMotorcycle.com Classifieds!Custom DynamicsDan Vance RacingLeslie Kay's
Motorcycle.com
Old 09-27-2009, 07:54 PM   #1 (permalink)
swordfish is on a distinguished road
270 degrees 103ci 255 cams pwc111
i need help with a heat problem, 07 streetglide s/e 103 with 255 cams, powercommander111 rhinehart 2into1 with correct map for that set up, 80 degree day 270 degrees!!!! checked digital gauge and is correct, i know i need an oil cooler,but i know thats not going to bring it down enough. i know the 255 cams are part of the problem but 270 degrees!! oh yes the bike runs great except for the heat.
swordfish is offline   Reply With Quote
Old 09-27-2009, 08:25 PM   #2 (permalink)
dynojet
i would like to see if mr. dynojet might have a richer map i could try for this setup.
Old 09-27-2009, 08:38 PM   #3 (permalink)
strokerjlk's Avatar
oil temp of 270 is normal and fine for 80 deg day.
maybe you could use a good tune.
remember the ideal head temp is 300 deg so running 270 on oil temp is not uncommon.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 09-27-2009, 09:50 PM   #4 (permalink)
i'v heard the s/e 255 cam is an epa cam and very little overlap, could you suggest a better cam for this setup, i do like the low end torque, i dont race it but do like the power when i need it.
Old 09-27-2009, 09:58 PM   #5 (permalink)
strokerjlk's Avatar
SE 204
Andrews 26
HQ 500
Andrews 54
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 09-27-2009, 10:05 PM   #6 (permalink)
Moneygreen
arealinvestor is on a distinguished road
If you want to stay with SE the 204 & 203 are ok cams.The 204 would be my first choice of the two.Are there better cams out there certainly.Lots of guys on this site running Woods & Andrews!!!
Craig G.
Old 09-28-2009, 01:59 PM   #7 (permalink)
Site Sponsor
I have attached a richer map with a bit of timing taken out at smaller throttle ranges. Give this a try, but I would not expect a massive drop in oil temp over it.
I would not write off a oil cooler as "not dropping the temp enough". It would be the first place I would look if the temp is your main concern. You have already said that the bike is running and performing well, which in my opinion, means that it is not dangerously lean.
See if this helps and let me know
Old 09-28-2009, 05:27 PM   #8 (permalink)
thank you for map
i'll install an oil cooler also, and thanks again for the quick response.
Old 09-28-2009, 11:47 PM   #9 (permalink)
seems to run cooler
tried the map you sent, and yes its running cooler about 260 ran it hard today and yes i think it helped, ordered oil cooler from hd and that should do it, thanks again.
Old 09-29-2009, 01:48 AM   #10 (permalink)
Coolmaker's Avatar
Whew, 270 normal... WTF????? My 104, runs 195 on a 100 degree day.... AND it is NORMAL.... LMAO
06FLHRCI
Old 09-29-2009, 01:55 AM   #11 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
The last time I had a bike run that hot it was sumping.
Old 09-29-2009, 04:20 AM   #12 (permalink)
strokerjlk's Avatar
check a few more!
and not with a H-D led digital thermometer
The Following Information was provide by
Harley- Davidson Service, 3rd Floor.
At what temperature will Harley-Davidson Motorcycle Oil
break down?
This oil has been designed for use at temperatures up to 300 deg F for extended periods with no significant breakdown.
5. What oil temperature is best for my Harley-Davidson?
A good oil operating temperature range is 200 deg to 240 deg F. Water condensation and acids tend to build up in the oil if the temperature is consistently below 180 deg F,
and oil thickness can become marginal at temperatures above 300 deg F.
I see a lot of higher comp builds
and a lot of stock camed motors running 260-275 deg so that's why when I saw his build a 103 with 255 cams running 270 I say normal.
actually see more run above 240 than I see below.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 09-29-2009, 08:29 AM   #13 (permalink)
Coolmaker's Avatar
check a few more!
Did not check it with their dipstick, I have a gauge ,and checked it with a professional thermometer also.. The only time my bike had a temp like that it was sumping after the SE camplate was put in. Changed that garbage out and now it does not sump, temp went way down..
06FLHRCI
Old 09-29-2009, 08:34 AM   #14 (permalink)
strokerjlk's Avatar
guess thats why they call you coolmaker!
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 09-29-2009, 11:08 AM   #15 (permalink)
could you explain sumping?
how does sumping result in heat? never heard of it.
[IMG] code is Off
