American Side Road CycleBub EnterprisesPro PadMotorcycle.com Classifieds!Custom DynamicsDan Vance RacingLeslie Kay's
Motorcycle.com
Old 09-21-2009, 07:57 PM   #1 (permalink)
midlandray is on a distinguished road
883/1200 conversion map pcIII
hi there i have a 2007 883/1200 conversion i downloaded the map offof the dynojet website for 1200 sportster with the screamin eagle hi flow ac and vance and hines straight shots but the bike runs way lean lots of popping and white plugs
the conversion comes with 9:1 comp ratio pistons can u help me with the map thanks if u can
bike also has stock cams and 883 heads
midlandray is offline   Reply With Quote
Old 09-22-2009, 01:37 PM   #2 (permalink)
Site Sponsor
Aside from the popping, what does the bike do that you do not like? You really cannot base the tuning on plug color, so we need to do it either on seat of the pants or via a dyno shop.
We do not have 883/1200 conversion maps. We can try to tweak the 1200 map to work. For a quick test use the buttons and increase the low, mid, and high by 1 bar and ride the bike. If it is better try one more bar. Let me know if one or the other makes the bike run better and we can go from there.
Old 09-22-2009, 03:39 PM   #3 (permalink)
the bike pings hard if i come off theline hard and there is a mild ping in the midrange if roll on the gas hard the bike rins real hot too like it did before i put in the power commander on the 883
i also tried the buttons on the pcIII but i cant seem to get enough fuel to it from the neutral position all the way up to full rich
Old 09-22-2009, 04:16 PM   #4 (permalink)
Site Sponsor
Give the attached map a try. It should be better than what you are using.
[IMG] code is Off
