According to the Power Commander website that map is for:
M816-009 *Advanced Map*, Vance and Hines Straightshots HS slip-ons, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Fuel table 1 is rear cyl
Straight shot slipons on a 883 with what i assume to be a stage 1 screaming eagle kit, If you are telling me that it will work I will try it as per your suggestions, I would just like to be sure.
Ill try this map
M817-006 *Advanced Map*Vance & Hines Short Shots Staggered, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Fuel table 1 is rear cyl
My only concern would be airflow, Would the Screamin Eagle air filter setup be comparable to the Heavy Breather kit, do they allow for the same amount of air flow?
Thanks,
Ken
