JekillandHyde.euRRcycles.comLeslie Kay'sCustom DynamicsMotorcycle.com Classifieds!Motorcycle-Communication
GoFreeCreditReport
Old 08-23-2009, 08:28 PM   #1 (permalink)
Knowledge Seeker
srigas's Avatar
srigas is on a distinguished road
Map Request - 15th Anniversary Fatboy 2005
I need a map for a 15th Anniversary Fatboy 2005 with V&H Big Radius 2 into 1 pipe. The bike has a stage one hd download, hd stage 1 air cleaner, 95 ci engine and stock cams (stock bike except for pipes). I have a map from a dyno session for this bike when it had a V&H propipe hs. I have not ried it. Not sure it would be the same. Thank you for your help.
2005 HD 15th Anniversary Fatboy
Stage 1 AC
95ci
Power Commander USB
srigas is offline   Reply With Quote
Old 08-25-2009, 02:02 PM   #2 (permalink)
Site Sponsor
I would suggest at least starting with the map you have. It will give a base to start with.
Old 08-25-2009, 02:38 PM   #3 (permalink)
Knowledge Seeker
srigas's Avatar
Ok I will try it and report back.
Stage 1 AC
95ci
Power Commander USB
Old 08-25-2009, 08:59 PM   #4 (permalink)
Knowledge Seeker
srigas's Avatar
Map Assistance Dynojet
I tried my map attached, but got a lot of off throttle loud pops above 3000 rpm. Bike seemed to run fine, but it sounded like a shotgun going off during off throttle runs above 3000 rpm. Please help.
File Type: zip Propipe_HS_Gary D.zip (572 Bytes, 1 views)
Stage 1 AC
95ci
Power Commander USB
Old 08-26-2009, 11:27 AM   #5 (permalink)
Site Sponsor
Something is wrong with the attachment. I cannot open it.
Make sure you have new exhaust gaskets and that they bolts are tight and the pipe is sealed.
After that, try adding 20's to the map int he 0% column from 2,000 rpm and higher. Let me know if that helps.
[IMG] code is Off
