BikeBanditCycleGear.comMotorcycle-CommunicationFuel MotoJekillandHyde.euMotorcycle.comAdvanstarMotorcycleShowsDiamond Bar Choppers
Bike Bandit
Old 08-23-2009, 07:11 PM   #1 (permalink)
Boz727 is on a distinguished road
Mr. Dynojet - PC III Map for 1999 FLHRCI with MM EFI
Mr Dynojet, I am finishing the install of PC III and AN Big Sucker and can't seem to find a PC III map that is close to my set-up and hope you might be able to help. I have the following:
1999 FLHRCI
Stock Twin Cam 88
Magnetti-Marrelli EFI
Stock ECU (as far as I can tell)
Stock Headers
Hooker Tuned Flow Slip-ons biased to "H" (horsepower vs torque)
Arlen Ness Big Sucker AC
PC III
Thanks in advance for any help you might be able to provide
Boz
Boz727 is offline   Reply With Quote
Old 08-25-2009, 02:00 PM   #2 (permalink)
Site Sponsor
Try the M802-312 map first and let me know how it works for you. With some feedback from you I may be able to make some suggestions if you have any issues.
http://www.powercommander.com/powerc...mdl=31&yr=1999
Old 08-26-2009, 12:12 AM   #3 (permalink)
Thanks for the map recommendation. I'll give it a shot and let you know how it works out.
Old 09-14-2009, 08:47 PM   #4 (permalink)
I finally got everything installed and was able to test ride the map M802-312. The bike seems to be running pretty good during acceleration but I do have popping on deceleration. I don't have a tach to indicate the RPM range where this happens but the popping occurs at or near 0 throttle and starts at anywhere from 50 mph in 5th gear and then at lower speeds as gearing drops (40-45 mph in 4th, 30-35 mph in 3rd, and so on). The popping typically continues from the speeds indicated above as slowing continues almost until I am stopped. As a side note, I did have some popping on deceleration prior to installing the Big Sucker and PC3 also but did have slip-ons installed without any fuel map modifications. Any ideas?
Old 09-15-2009, 12:17 PM   #5 (permalink)
Site Sponsor
Try the attached map and see if it help with the popping. I also tweak the low speed timing to see if we can improve the throttle response. Let me know how it works.
Old 09-15-2009, 07:23 PM   #6 (permalink)
I had to take a step back. After scratching my head a bit and contacting previous owner and then his original HD dealer I have found that I have had a Stage 1 ECM update (bought the bike used), so I grabbed map M802-313 from Dynojet website and installed (map is for the same configuration as M802-312 except included Stage 1 ECM). I still have basically the same popping issues (maybe even a bit worse). Sorry for the confusion, but I do appreciate the help thusfar.
Old 09-16-2009, 11:52 AM   #7 (permalink)
Site Sponsor
Try this. Add 15's to the 0% column of the map from 2,000 rpm and higher. Then add 10's in the 2% column from 2,500 RPM and higher. Load that and see of the popping is reduced.
[IMG] code is Off
