05-17-2009, 10:45 PM
Map request for 03 EGlide w/Cams
First time post here. I checked the PC Site and could not find a map for my set up. Was hoping I could get one here. Please let me know if that is possible. Currently using M807-125 with my PC. Thanks.
2003 EGlide FLHTi TC88
Rinehart TD Exhaust
Big Air Sucker
Stage 1
Andrews 26 Gear Drive Cams (just added).
05-18-2009, 02:25 PM
Site Sponsor
Ok, the attached map should be a good starting point. Try this and report back. We can work from there.
05-18-2009, 02:40 PM
Great. Thanks.
05-18-2009, 03:07 PM
hmmmm ... my command center won't open the .djm format file. I can open the .map format ones. I will go onto the pc site and see if I need something else. been a while since I have made any changes .....
05-18-2009, 03:53 PM
Site Sponsor
You have an older PCIIIr (serial cable) style unit and not the PCIIIusb?
05-18-2009, 04:01 PM
That is correct ... been a great unit and has never failed me.
05-18-2009, 04:13 PM
Site Sponsor
Here you go
05-18-2009, 04:30 PM
thanks. will loaded on the bike later tonight. should be able to test it either later tonight or tomorrow evening. will let you know. thanks again.
05-19-2009, 07:58 PM
Just got back from a 30 mile test ride. A little back roads and a little hi-way. Definitely the map you provided woke up the bike and the cam finally gave me some seat of the pants performance. I compared the 2 maps and there was some big differences, which obviously the one from you really worked. No back firing at all either. Will be interesting to see what the gas mileage turns out to be.
Anyway, thank you very much for the map !!
05-19-2009, 08:04 PM
Site Sponsor
I am glad I could help. Let me know about the mileage after you ride for a while. It should be ok, but we can try some things if need be.
06-11-2009, 10:48 PM
Bike runs strong and no backfires to date. Mileage is just a little under 36 mpg. Is that about the norm? Was hoping to be 40 or more. I was doing town and highway driving to get the 36. If that is about the norm then I will try to learn that I can still smile while not pulling on the throttle as hard...
06-11-2009, 11:15 PM
mooooving out!
You should get 43 or better at 70 on flat highway miles. Your map is better, but a good tuner could tighten it up.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
06-12-2009, 10:51 AM
Site Sponsor
Try this version. I leaned out the higher speed cruise area. Fuel economy should be better on the highway with it.
06-12-2009, 01:32 PM
43 would be good. Will load up the map later today and watch it for a while.
Thanks for the adjustments!! Will give it a try.
