Maps for HD Race Tuner - Page 6 : V-Twin Forum: Harley Davidson Forums
Old 08-26-2010, 11:47 AM   #76 (permalink)
jessthejtrain is on a distinguished road
06 Road king
I have an 2006 Road king with Rinehart Tru Duals, and a K&N air charger anyone have a map that could help?
jessthejtrain is offline   Reply With Quote
Old 09-04-2010, 02:58 PM   #77 (permalink)
AirPatrick is on a distinguished road
Hi there. I have a 08 Fatboy with SE pipes (80496-07) and a SE "Ventilator" performance air cleaner kit (28721-10 I know it's suppose to be only for 2010 Softail, but it fits perfectly) installed.
I also bought the SEPST and I would like to have a really good map to work with, thank you.
AirPatrick is offline   Reply With Quote
Old 11-02-2010, 03:11 PM   #78 (permalink)
George Margerum is on a distinguished road
I need sert map 04 softail tc 95
heads HTTC (HEADQUARTERS)
tc95 inch kit
10.5.1 compression
HQ575g cam
Stock intake manifold
S&S airflow
vance& hines radious pipes
protuner (head quarters)
racetuner
I need a base map to start out with. The engine being 575 cam and redone engine, want a base map with the right timing essentials and such..
George Margerum is offline   Reply With Quote
Old 04-10-2011, 09:36 AM   #79 (permalink)
baggerbenn is on a distinguished road
i need help if anyone can...
2011 flhtk 103" stock displacement with seac,stock headpipes with cat. removed,andrews 54h cams,se pro super tuner,cvo bagger mufflers with fullsac cores. had bike dyno tuned 2 x so far. runs great,just under 100hp/100tq to the wheel but ... 2500-3500 rpms under load it pings bad. dealer told me to rev it past that point and it's fine. i dont buy it. anyone have a map for this? or can point me to a dealer with a great dyno tech in s.e. pa? send me an im or email.
thanks
ben
baggerbenn is offline   Reply With Quote
Old 04-10-2011, 10:06 AM   #80 (permalink)
JOHNNYWISHBONE's Avatar
JOHNNYWISHBONE is on a distinguished road
Good tune = no ping!
thanks
ben
there is no reason for you to be happy about this. with the dyno, you didn't get what you paid for. twice. i've got a dyno tuning guru, but he's 3000 miles from you. it sounds like you set up the bike nicely. you didn't mention oil cooler. i'm sure you'll get some decent advice from forum members. to me, "pinging" is the sound of aluminum leaving your piston tops. take care, jp
JOHNNYWISHBONE is offline   Reply With Quote
Old 04-11-2011, 01:17 PM   #81 (permalink)
tomdubya's Avatar
tomdubya is on a distinguished road
thanks
ben
This is a super tuner map. you can copy the maps to your existing (cut/paste) if you like.
No decel pop, 38 to 42 mpg, afr 13.4:1 . I know the cams are different...try it..tweak it.
Your mileage may vary.
I also have a map for a set of crane 290-2 if needed.
T-dub
http://www.v-twinforum.com/forums/at...&d=1262828234?
2007 Ultra, SE 103"
SE 50mm tb
Branch PT heads re-machined by Hannan's
.030 cometic, cr 10.5:1
Woods TW-7H cams
Feuling race lifters
Rinehart TD's
SEST
Tuned by RC Cycles, Hayward, CA
tomdubya is offline   Reply With Quote
Old 07-18-2011, 07:22 PM   #82 (permalink)
Zoidberg is on a distinguished road
any maps for a 2011 Sportster with V&H Shortshots (with quite buffles) and Rebuffini Meteor air cleaner ?
Zoidberg is offline   Reply With Quote
Old 07-21-2011, 04:22 PM   #83 (permalink)
rpl33 is on a distinguished road
i have a 2011 road glide 103 , changed breather se, pipe two in to one v h. every thing else is stock tried differnt maps none close enough to work with any one have the stock map or on that is good for my current set up any help would be greatly appreciated.
rpl33 is offline   Reply With Quote
Old 04-16-2012, 01:44 AM   #84 (permalink)
cowboy4x4n is on a distinguished road
sert map
I need a map for a 2005 fxstb 95" 10-1 compression, ported factory heads, S&S 585 easy start cams, big sucker air cleaner and python 3 pipes.
Thanks guys
cowboy4x4n is offline   Reply With Quote
Old 04-16-2012, 07:59 AM   #85 (permalink)
troydba is on a distinguished road
I seriously recommend you spend roughly $300 to have a reputable SE Tuner Tech. dyno tune your system. It was the best money I ever spent. Maps to get you by until you can get the dyno tune can cause more problems than not if you don't have an extremely close match. Ask around your area for the top 2 tuners by rep. and referral and pay to have it tuned to the max! You won't regret man! Best Wishes...
troydba is offline   Reply With Quote
Old 05-02-2012, 11:52 AM   #86 (permalink)
tuner
troy i have every intention of getting a dyno tune. in order to do so i need to put on about 500 break in miles before my tuner will touch it. thats why im looking for a map close enough to get me by till then
Old 11-29-2012, 05:43 AM   #87 (permalink)
lanoseal1 is on a distinguished road
Map needed for 2009 FLHTCUI
Hi all
I have a 2009 FLHTCUI
Heads Done, high Flow
Enlarged Valves
SE Breather
SE Pipes
103 Kit
Andrews 37H Cams
Flat Top Pistons
SEPST
Trouble starting when hot using SE 104 Cam maps.
Can anyone help me with something to suit Andrews 37H Cams ?
Dave
lanoseal@gmail.com
lanoseal1 is offline   Reply With Quote
Old 11-30-2012, 10:05 PM   #88 (permalink)
tomdubya's Avatar
Originally Posted by lanoseal1 View Post
Hi all
Enlarged Valves
SE Breather
SE Pipes
103 Kit
Andrews 37H Cams
Flat Top Pistons
SEPST
Dave
lanoseal@gmail.com
Dave,
Try this map.....might be a good starting point.
I don't know if it matters, but is your bike throttle by wire?
T-dub
2007 Ultra, SE 103"
SE 50mm tb
Woods TW-7H cams
Rinehart TD's
SEST
Old 11-30-2012, 10:10 PM   #89 (permalink)
tomdubya's Avatar
thanks
ben
Thats like telling the doctor your knees only hurt when you bend them, and he says "well...don't bend them then."
2007 Ultra, SE 103"
SE 50mm tb
Woods TW-7H cams
Rinehart TD's
SEST
[IMG] code is Off
