Old 11-17-2008, 01:24 PM   #1 (permalink)
wmossy is on a distinguished road
Need A Map Tw6-6
Have a buddy in search of a SERT map for a 2007 96" with the TW6-6 cam. Any suggestions would help.
WMOSSY
2001 FATBOY 117" Axtell cyls, Axtell Pistons, R&R Stage V heads, RR615 cams, R&R Rollers, R&R internal Cam plate & New HO OEM pump, ADJ pushrods, SE CVO 4 3/8 crank worked by DARKHORSE, Zippers 54mm TB & 1.8 Manifold, 2001 VROD injectors, K&N open Filter, D&D 2:1 with perf baffle, Rivera Pro Clutch, basket & TPP, TMAT Map 514, HD PREM Oil cooler, BAKER DD6
wmossy is offline   Reply With Quote
Old 11-17-2008, 06:44 PM   #2 (permalink)
SERT map help TW6-6
Any one running this cam in a 96" with the SERT?
WMOSSY
Old 11-17-2008, 06:51 PM   #3 (permalink)
I paid.........did you??
MaineUltraClassic's Avatar
MaineUltraClassic is on a distinguished road
What exhaust is he using?
That is a big question when trying to use a map, the exhaust makes a huge difference.
Steve
95" Powered by Big Boyz Heads, Woods Cams, Doherty PowerPacc w/ Powervents,
TTS Mastertune, D&D Fatcat w/ Quiet Baffle, Hillside 46.5mm TB, & Cometic Gaskets
Built by Me, Tuned by Bean
MaineUltraClassic is offline   Reply With Quote
Old 11-17-2008, 06:54 PM   #4 (permalink)
Moneygreen
arealinvestor is an unknown quantity at this point
That's alot of cam for a stock 96ci???? I hope he increased the comp to about 10 to 1 in order to make full use of that cam!!!!!!
Craig G.
arealinvestor is online now   Reply With Quote
Old 11-17-2008, 08:13 PM   #5 (permalink)
drmustang is on a distinguished road
I've got a Woods TW6-6 in an '07 Dyna, '96 and it runs great. I'm in the process of going to a 103" with the same cam and need a PCIII break in map if anybody has one for a 103" and Woods 6.
drmustang is offline   Reply With Quote
Old 11-17-2008, 08:41 PM   #6 (permalink)
Moneygreen
It would run alot better if you ran some more comp!!!!!If your running stock comp at 9.2 with a 40 intake close cam,your dynamic comp will be even lower!!!! Bump it up to about 10 to 1 static comp & really watch it tear your back off!!!!!!
Craig G.
Old 11-18-2008, 05:24 AM   #7 (permalink)
V&H Big Radius
Steve
V7H Big Radius and a 4* advanced cam key
WMOSSY
Old 11-18-2008, 05:26 AM   #8 (permalink)
Bobby Woods
At the recommendation of Bobby Woods he is putting the 4* advance cam key in. When he bumps the motor up to a big bore kit with head work he will remove the key. This way purchase cams only once.
WMOSSY
[IMG] code is Off
