Originally Posted by DynojetResearch
buddyrm,
as a side note I would really recommend you replace the stock aircleaner assembly with a open style. There is quite a bit of power to be gained.
To answer your question about negative fuel adjustments. There are situations where the bike can be richer that idle. You cannot say that bikes only ever need to have fuel added.
Now, with your bike and the fact you have altered the exhaust you may need to add fuel at the larger throttle openings. For sure if you change the aircleaner you will need to.
The map you are running also has some timing added at wide open throttle. This may have been too mcuh for your riding situation.
I have attached a modified map for you to try. Let me know how it works.
OK... This map seems to be better but I still am getting some pinging with 91 fuel through the 2800-3200 RPM transition under load with 25-40% throttle in 2nd gear acceleration. I switched to 94 octane and the pinging has stopped. 94 Octane is not readily available everywhere. So 91 should be the normal octane that I need to tune too.
So looking at the map in this range. There is only a positive setting of 3 to 8 % fuel addition. Not much considering using the screaming eagle exhaust and the K&N 1499 replacement filter. Air Flow should be not to restrictive at that setting so I assume that the engine is breathing better at that RPM range.
Is this something I should be concerned about? Looking at the fuel trend in that RPM range and throttle setting, it seems there is a quick dropoff of fuel deliver that in my opinion maybe causing all my grief. If indeed there should be a fuel dropoff at that transition with the Dyno testing, it should be more a gradual tappering and not as drastic as it is now. see attachement image.
I understand that pressure waves maybe at play that require the use of less fuel delivery at a certain RPM than others and this would account for the radical alteration of the fuel delivery. But there are different models of screaming eagle exhaust which mine happens to be the 65299 model. This one may have radically different pressure wave characteristics than the posted maps for sceaming eagle exhaust slipons.
Anyway in you opinion, would it be not safe to make it more a gradual tappering transition in fuel delivery at that RPM range then it is now to help the pinging? Since at cruise speeds at 80 MPH, the 2800 to 3200 RPM setting, the throttle lives in the 10 to 15 % range usually and the fuel delivery seems to be OK for those settings.
The purple line in the attached image would make more sense as a less agressive tappering off of fuel delivery to ease the pinging.
Please let me know what you comments are on the above.
Also on a side note: How do we know that the PC3 I have is within normal operating parameters?. What I mean is that it is acurate in adding exactly 20 % more when required and that timing is accurately controlled being the the PC3 acts as the "man in the middle" design. Is there any built in diagnostic that can be used to determine correct operating signal margins.? Does it do its own diagnostic at power on and report any abnormalities? I am a software & hardware design engineer and that would explain all these technical questions.
Feel fee to add as much technical detail as you feel comfortable in forwarding.
