Diamond Bar ChoppersStainless Ride Specialty AccessoriesSportbikeTrackGearLeslie Kay'sBikeBandit
Custom Dynamics
Old 03-17-2008, 04:41 PM   #1 (permalink)
Marty59 is on a distinguished road
Develop a TMAX base map from a PCIII Map?
My TMax should be here today. I have talked with Zippers and also received a suggestion from the forum for a starting base map (actually several suggestions). I currently have a PCIII on the bike that was tuned last year. I am only changing the exhaust system, from a set of Cycle Shack Slip-ons to a D&D 2-1.
Is it possible (or advisable) to use the PCIII timing map from last years tune (with the slip-ons) as a starting point in developing a base map for the bike with the new D&D exhaust.
It looks like to me that the Tmax has many more inputs for timing than I can find in the PCIII map. Again, is it feasible and has anybody been able to translate backwards from the PCIII to create a TMax base map.
Of course I am assuming that the base timing map from the tune last year would be better than one of the canned maps - saying you can make the translation.
Any thoughts on feasibility?
M
Marty59 is offline   Reply With Quote
Old 03-17-2008, 05:44 PM   #2 (permalink)
ToBeFrank's Avatar
ToBeFrank is on a distinguished road
You can't do it. Your stock timing is stored in your ECM. The PCIII map is offsets from that timing. Besides, the stock ECM + PCIII is using the MAP to determine timing. The tmax uses TPS. You can't easily convert one to the other.
ToBeFrank is offline   Reply With Quote
Old 03-17-2008, 08:04 PM   #3 (permalink)
I figured if it was do-able someone would have done it - thanks Frank
[IMG] code is Off
