Originally Posted by jpowell490
Hey All,
Well I think I got the SERT pretty well figured out. I increased the VE tables on the front and rear cylinders by three mouse clicks throughout the range. Bike seems to be doing well, plugs are clean - white. I shined a flashlight down in the back plug hole today and the piston is super clean all the way around except in the very middle where the plug fires. It looks like black - tan carbon build up. Is this normal or do I have it too rich or too lean?
My bike is a 2008 xl 883 with 650 miles on it, so it is pretty new.
Thanks for any help.
Jason
Hi Jason.
You really should be setting this up on a dyno, not just playing with it.
You can do a lot of harm to the engine without knowing just what the result of the adjustments are doing to the engine.
You can burn a piston, or ping a hole through one, and no, it will not be under warranty because you caused it.
Please have a dyno tech set this for you.
I'm Just Sayin'...
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
92.85 Torque 80.08 HP
Professional Rockat Surgen
Disclaimer.
