Old 02-26-2008, 05:26 AM   #1 (permalink)
scourge's Avatar
scourge is on a distinguished road
Sert map, close but no cigar
I was trying figure out which canned Map to put on my bike before it goes in for tuning. But there maps that are close but not exact, so I'm trying to figure out which parameters I try match first.
Displacement
cam
injector
compression
heads
intake
exhaust
I can find a map thats close but the cam is wrong or should I take one where the compression is correct but the heads are wrong and the cam is wrong?
Any thoughts?
Scourge
06 RK Custom
95"
Forged SE pistons 9.5:1
.030 head gasket
Andrews 31G
Arlen Ness Big Sucker
Samson Rolled Thunder
scourge is offline   Reply With Quote
Old 02-26-2008, 05:05 PM   #2 (permalink)
Road King Man
Zadok's Avatar
Zadok is on a distinguished road
Probably wouldnt spend too much time with it. If you have
a good tuner he/she should be able to pick a good starting
point for the tune.
You also have to figure this...
If the tuner has been around awhile, and has tuned
the SERT very ofter, then they should have a map
already in the system that is similar to what you
would need. They will more than likely upload this
map as a start point and make final tuning for
your particular bike set up.
Just make sure you have a good dyno tuner lined up.
Just Ride....
Zadok is offline   Reply With Quote
Old 02-26-2008, 06:18 PM   #3 (permalink)
Axe Man
BVBOB's Avatar
Providing you have 25 degree injectors I would use the map for the 203 cams with flat tops. cal id 141mj016.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
[IMG] code is Off
