TPS troubleshooting : V-Twin Forum: Harley Davidson Forums
Old 06-06-2007, 08:24 PM   #1 (permalink)
bashir wants to know Dino or Syn?
TPS troubleshooting
Does anyone have information on the correct voltage values expected from the TPS? Mine, (2005 FLH), shows .380 at idle and 2.8 at WOT. SmartlinkIV thinks this is only 10 idle and 32 degrees WOT (obviously WOT should be closer to 90 degrees). What voltage should WOT be? Me thinks closer to 5.0 volts.
Tnks!
bashir is offline   Reply With Quote Quick reply to this message
Old 06-07-2007, 07:56 AM   #2 (permalink)
2005 Road King Classic
bbrowncods's Avatar
bbrowncods wants to know Dino or Syn?
TPS and volts
On the DTT the Idle volts is approximately .4 volts; 50% is about 2.0 volts and 100% is 5.0 volts. I am sure the Delphi is close since they use the same Throttle body and sensor.
05 Road King Classic - Sierra red pearl/RB Racing LSR 2-1 Titanium ceramic w/Chrome shields/98" RevPerf BB/37g cam's/Stock 99B lifters/Stage 2 CNC'd heads by R&R(GMR) 9.7 CR/Stock Throttlebody and SE air filter/500cc injectors/TTS and modified EFI to '07 w/O2 sensors/Super Premium Oil Cooler/SE Clutch spring w/Easy-pull ramp and a bunch of this and that!
People afraid of the government is tyranny, government afraid of the people is democracy.
bbrowncods is offline   Reply With Quote Quick reply to this message
Old 06-07-2007, 08:01 AM   #3 (permalink)
GearGrinder wants to know Dino or Syn?
Don't know the exact closed throttle tps volt specs for your bike but every tps I've worked with has a range of approx .5 to 4.5 Volts.
GearGrinder is offline   Reply With Quote Quick reply to this message
Old 06-09-2007, 07:16 PM   #4 (permalink)
Thanks. I found with a good EFI, the voltage is indeed .5 to 4.5 volts. Obviously I have a defective EFI as it pulls the voltage low. Mystery solved.
[IMG] code is Off
