» Buyers Guides |
04-11-2007, 10:43 AM
#751 (permalink)
Originally Posted by Davidswideglide
I have been reading all the post and studying the installation instructions and I think I am going to pull the tricker and install the auto tune on my 2006 wide glide. Sounds like a really good system and won't alter the ability to read codes or lose the auto cancel turn signals and ect.. The only thing at this point that intimates me a little, is the computer part of it. And what to do if I have trouble with the system. Sure can't take it to the dealer and have them work on it. But I know my bike can and will run better with the system installed. I just hate how lean the factory has these things running.
David
I totally suck with computers, but you would have to be brain dead not to be able to set this up. You can always call zippers for help.
I did when i was having a brain deag moment.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
Thundermax ecm and Auto Tune
Samson true dual fishtails.
04-11-2007, 12:18 PM
#752 (permalink)
Originally Posted by mori55
So what would be ideal for city and highway driving? I have my map leaned out from 1792 to 3072 at 14.05.
How does that sound?
I guess it depends on what RPM range you cruise in. I have the same type hump in my cruising RPM maps. The AFR is in the mid 13s at and just off idle leaning out to the low 14.s in my cruising TPs and richens up to the mid 12s at WOT but mine starts in the low 2000s and goes to about 3300 RPM (I'm not on my laptop so I can't look at the exact numbers) but on my Ultra Classic that is where I cruise. I don't usually run much below 2200 RPM and 73 MPH is 3000 RPM in 5th gear so I can go up to about 80 in the leaner range, but the faster I go the more I have to twist the gas because riding an Ultra on the interstate is a lot like pushing a sheet of plywood down the road.
04-11-2007, 07:57 PM
#753 (permalink)
Update smartlink
Anybody tried updating smartlink mine keeps saying crc failed when it goes to install update?
04-11-2007, 08:09 PM
#754 (permalink)
Mine updated last week to the newest software level no problem...
version 17.10
04-11-2007, 09:09 PM
#755 (permalink)
Sub Par Member
Newest version is 17.11.
I think it came out in the last day or two. I just installed it with no problems, although I've no idea what changes are in it. Looks like it might contain some new maps.
04-11-2007, 09:19 PM
#756 (permalink)
CRC stand for "cyclic redundency check" which means the software is checking to make sure it is good after the download, or something along those lines.
I would suggest that you try to donwload again and see what happens, worst case, you uninstall the software and install it again from the TMAX web page.
alperin1
04 FLSTCI
95 BB
BigBoyz ported heads
9.8:1 compression
SE204 CAM
SE HC pistons
ThunderMax with Autotune
SuperTrapp SuperMeg
SE Air Cleaner
peanut butter jelly time
04-12-2007, 04:31 AM
#757 (permalink)
Originally Posted by plymouth4
Mine does the same thing also and I have driven over 50 miles, if it sits 10 minutes and when I restart will act like it is sneezing through the air cleaner. When I started it up today cold 65 degree engine temp it ran 1 minute and snezed and cut off. Thought it would have learned something by now. When mine gets good and warm it it runs fairly good with the exception of snapping the throttle 2 times and it sneezing while it was warm
I experience the same thing, except mine is when I blip the throttle at low RPMs. Thanks to the posts later on in this thread, I looked at the Accel Fuel setting in the manual and it has the following "Tuning Tip":
If you experience a pop or misfire in the intake tract while
blipping the throttle at lower RPM’s, lower Accel fuel value until the
situation improves.
Mine was set to 12.0 by the base map so I lowered it to 8.0 (the manual says Zippers recommends between 8-14). I haven't ridden it yet to see if it corrects the problem or not, but I'm crossing my fingers.
04-12-2007, 09:02 AM
#758 (permalink)
WMD TEST PILOT
Auto Tune
Can you plug it straight into a 07 FXST or do you have to purchase the Thundermax ECU aswell
04-12-2007, 09:42 AM
#759 (permalink)
You have to buy the whole unit, it takes the place of the stock ECU.
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
04-12-2007, 10:48 AM
#760 (permalink)
Ok maybe dumb question and maybe already covered but here goes, Ordered the Thundermax w Autotune for my 07 Ultra from cyclespot...what is the sight and is there a sight to download a basemap that is close to my set up?
04-12-2007, 11:21 AM
#761 (permalink)
Sub Par Member
Here's the ThunderMax website.
And here's the Zipper's site.
All of the maps will be included in the software, but do a software update through the SmartLink program when you get it installed. There's a newer version out.
You can follow the links at the ThunderMax site here (scroll to the bottom of page) and download the manuals and software if you want to get a jump on things.
04-12-2007, 12:04 PM
#762 (permalink)
Trip meter question
Does the a & b trip meter still work on the dyna o6's and all 07's with the auto tuner??
04-12-2007, 12:25 PM
#763 (permalink)
Why wouldn't it work????
2005 Deluxe
95
BigBoyz Heads
Andrews 37g cam
04-12-2007, 01:20 PM
#764 (permalink)
Read on another forum that there was a issue with the A&B trip meters. I am so on the fence with this and just need to get over it and order one!!
04-12-2007, 01:27 PM
#765 (permalink)
My set up is going to be SE air filter (stage 1 HD) Fullsac crossover elimiantors and Supertrapp SE slipons...any one running this with the Thundermax A/T ? Is there a map for this or one thats close enough to start? My unit will be here Monday ......
