Originally Posted by nw_guy4_fun
Two bad annoyances
The speedo is 12.5% fast (GPS). I have changed the front pulley to 30t and don't know to raise the frequency number by that amount or lower????
After a hot restart, like gas the bike hangs at a very high idle between 1500 and 2000. The only way for me to clear this is to come to a full stop and wait in neutral. It will then back down and behave from there on out. It does this every time though consistently until I go through this routine.
Any help is much appreciated
TIA
The GPS is great for checking the speedo, as long as you know that it lags a second or 2 behind the speedo reading, so you just have to maintain a speed for several seconds to verify.
Lowering the HZ value will lower the reading on the speedo, it will take several tries to get it right.
The high idle issue could be many things, just remember that the idle setting only functions at zero speed and zero TPS.
If you wish, set the log time in the Basic Parameters section to 0.2 seconds, then go out and get it hot, stop at your house, let it sit for the "fuel stop" time, and restart, ride a short distance until you get it to settle, and return home, don't ride to far or else the log will not have the restart on it.
Then post the downloaded .log and .dat files here.
