Wheeldock.comSumax.com LawTigersPro PadProCharger.comKomodoGear.comRacer SupplyD2Moto
Old 06-29-2008, 12:38 PM   #976 (permalink)
6th gear light after 30T pulley change
Will my light work any more and what do I change the frequency number to in order to get it right again?
TIA
Old 06-29-2008, 12:57 PM   #977 (permalink)
2005 Road King Classic
wkohn is on a distinguished road
TIA
I would try using the formula in the instruction for setting the VSS frequency number but instead of using the MPH put in your old pulley number and your new pulley number and put in the new value. It should get you close.
wkohn is offline   Reply With Quote
Old 06-30-2008, 07:25 AM   #978 (permalink)
Not FNG anymore
Curtis Shipp is on a distinguished road
Originally Posted by Dogwood View Post
I am curious as to why you have this area of the Front & Rear BLM Table "blocked out"?
I block the idle cells so they cannot retune. These cells control idle with 1's they can adjust to the afr you want but they cannot screw up your alpha #'s on decel. With 0's they cannot move anything. If you leave them open they will screw up your cold start settings.
Curtis Shipp is offline   Reply With Quote
Old 06-30-2008, 07:31 AM   #979 (permalink)
Not FNG anymore
Originally Posted by sdbryant View Post
Curtis, thanks for the response. The pop seems to happen between 1500-2500 rpm with the throttle closed on decel. I'm not sure which tps setting you are referring to. I have attached my latest map.
The tps voltage is what I was looking for. Make sure it is around .39 volts when closed.
Old 06-30-2008, 08:00 AM   #980 (permalink)
Not FNG anymore
Here's my latest map with the log file after a trip to the J&P Cycle open house. Any suggestions welcome. Thank you.
Try this. I leaned your afr 3%. Do not apply blm's let them work and pull fuel off. I worked on your timing some. I pulled some fuel off in your frt cyl trim. Your fuel mileage should get better. The decel pop you will have to let me know.
File Type: zip 062808 appliedreworked.zip (884 Bytes, 19 views)
Old 06-30-2008, 12:26 PM   #981 (permalink)
sdbryant is on a distinguished road
Thanks Curtis. Some great information. I will give this map a try over the next few days and post a follow up.
'07 Fat Boy
DTT TCFI-IID
V&H Big Radius 2to1
SE Heavy Breather
Wild1 Chubby Knuckle Bars
Cam (TBD)
sdbryant is offline   Reply With Quote
Old 06-30-2008, 01:31 PM   #982 (permalink)
Not FNG anymore
TIA
Where did the 30t pulley go? What is the purpose of it? I would like more low end on my 07' ultra. It is like starting in second gear compared to my 5 speed 05' dyna.
Old 06-30-2008, 08:09 PM   #983 (permalink)
cts1950 is on a distinguished road
Curtis
I did this mod to my 1999 ultra with a se 6 speed conversion and I wanted to add the IDS. Of course I did not need the speedo callibrater. The pully and belt should fit your 07 ultra
I cut and pasted this info from a earlier post by THEDRIVER
save $, get it all done
I got all my parts from ZANOTTI MOTORS, Baker 30 tooth # 30T-07 $115.00, 136 tooth belt # 40056-07 $169.00, also the IDS rear sprocket is a good idea to smooth out drive line # 40287-07 $ 197.00. and to correct speedo Dakota # 2210-0056 $ 92.40 because it will be off by 4.5 mph at 70 mph. all of the above was a HUGE savings about $ 230.00 worth. but you have to purchace on line to save. it is very easy. to check on orders you can call them. Patty i think ? 724-283-5419
good luck & enjoy. my $.02 worth
cts1950 is offline   Reply With Quote
Old 07-01-2008, 09:28 PM   #984 (permalink)
Baker and andrews make a 30t trans pulley, that and the HD HDI belt change the final drive ratio from 2.79 to 3.0 roughly. Nice change and 6th becomes useable but not unruly and the compensator is left intact.
CTS why the Dakota Digital device and not just adjust the speedo frequency in the DTT?
Old 07-02-2008, 12:07 AM   #985 (permalink)
I did not use the speedo adapter the dtt works well for that. I just copied that post in its entirety so not to edit someone else's work.
I used the 30 tooth trans pulley the belt and IDS on my bike. I noticed that the stock frequency works well with my combination with the se 6 speed trans. With my 103 motor I don't know if I am lugging but it is quite comfortable on flat ground at any thing over 2200 rpms. If I need accelerate or climb a hill I will drop to 5th.
Old 07-02-2008, 07:16 PM   #986 (permalink)
Dogwood is on a distinguished road
How would you be able to determine what frequency to put in the DTT MAP?
2006 Road King Standard
Dogwood is offline   Reply With Quote
Old 07-05-2008, 08:48 AM   #987 (permalink)
Re-worked Map
Curtis,
When you say do not apply blm's, are you wanting me to post my map after riding some without applying so you can see what's happening first?
I have noticed that I am getting some pinging going on again when I roll on the throttle to WOT, especially when riding 2-up.
Thanks again.
Steve B.
'07 Fat Boy
DTT TCFI-IID
V&H Big Radius 2to1
SE Heavy Breather
Cam (TBD)
Old 07-06-2008, 11:23 AM   #988 (permalink)
I adjusted mine by trial add error. I think the higher the number the lower the speedo reads. I used my gps for my gauge.
Old 07-07-2008, 04:47 AM   #989 (permalink)
I memory serves me correctly. I had to lower the number to lower the MPH reading and raise it to raise the MPH reading.
Old 07-07-2008, 07:36 AM   #990 (permalink)
Not FNG anymore
Curtis,
Thanks again.
Steve B.
The problem is to much timing. But you need the timing to get mileage. Go to user output and turn on nos and put in 2400, 3500, 33, 74, 60 on the right hand side. Put 5 degrees in the timing retard. This should take care of the roll on ping in high gear. You will still have all your timing in the lower gears because of the 60 mph min speed. You can try different settings when you understand how it works.
[IMG] code is Off
Motorcycle Forum Ducati Monster
