HD PipesKomodoGear.comMotorcycle.com Classifieds!RacerPartsWholesaleKewlMetal.comLawTigersPro PadArnottAirRideSpringfield ArmoryCellino&Barnes Motorcycle AttorneysStoneyStraps.com
Old 06-23-2008, 08:40 PM   #961 (permalink)
Karp13 is on a distinguished road
Its not a new site it is more for their car stuff.
I spoke with someone at DTT and they said they should be back up in a day or so. He made a joke that they forgot to pay the bill.
2007 FLHX
96" Stock compression
Andrews 26H cams
Ness Stage 1 Big Sucker
Thunder Header - Baffles tweaked to add back pressure
DTT IId
Karp13 is offline   Reply With Quote
Old 06-24-2008, 12:25 AM   #962 (permalink)
SpeedGlide is on a distinguished road
Here's a Q for the experts....
While I'm dickin' with my AFRs, I start to wonder just where the engine temp sensor is at and what is it actually measuring... head temp? case temp? Oil?
( I suppose that answer is in my service manual)
And the second and important question- What is the ideal operating temp for an EFI twin cam per the readings stored in the DTT? My last hwy run averaged approx 110-115 C.
Normal????
Too Hot?
Jason
SpeedGlide is offline   Reply With Quote
Old 06-24-2008, 08:49 AM   #963 (permalink)
Dogwood is on a distinguished road
The sensor is located on the front cylinder head just behind the horn cowbell, and it's measuring the head temp on the intake port side.
Normal????
Too Hot?
The ideal temp is debatable, but above 100C is considered operating temp.
I would say that 180C is too hot, but you can get there or above in stop&go traffic on a hot day with little wind though.
2006 Road King Standard
Dogwood is offline   Reply With Quote
Old 06-24-2008, 07:50 PM   #964 (permalink)
Excellent, thanks Dogwood!
SO- I would say an operating temp of 120C would not be hot at all for a head temp, correct? Anyone else care to comment?
Jason
Old 06-25-2008, 12:00 AM   #965 (permalink)
Broke
chef-beavis's Avatar
chef-beavis is on a distinguished road
Conflicting cures...
I have what my be considered a basic question around here but I don't see it already addressed around here. I am pretty pleased overall with my DTT and the bike has run well enough this summer to allow me to start chasing a couple annoyances without feeling like I mess wih it more than ride it. The two quirks are a slight burble/popping on decel around 1500-2200 rpm that seems to be getting a bit louder as of late, and a slight hesitation or even a sneeze off idle if you whack the throttle quick. I've read enough to see the decel popping is often solved by removing fuel from those cells with the tps at 0%. I've also seen plenty of mention that the Asynchronous Fuel Gain should be left alone in favor of a richer AFR in those lower cells for improving throttle rsponse.
So...how do I cure the popping by leaning the same cells I need to fatten to cure the hesitaion?
As always, any help would be greatly appreciated.
See my signature for my combo.
Chef-beavis
2006 FXSTBI
Big Sucker
Joker Machine Chopper pipes
DTT TCFI-IID
SE 4.89 Injectors
95-inch
HD Flat-top 10.5:1 pistons
S&S 585 gear-drive cams
Ported, polished, decked heads
Compression releases
HD adjustable pushrods
SE perf valve spring kit
Bigger intake valves? U tell me...
Diamond Cut heads and cylinders
Deuce Front End
Ness Fly-Hi Bars
chef-beavis is offline   Reply With Quote
Old 06-26-2008, 09:18 PM   #966 (permalink)
sdbryant is on a distinguished road
Converting a TCFI-C cable to a Palm cable
Trying to put together the Palm TCFI-II View setup for tuning my TCFI-IID on my '07 Fat Boy. Bought a Palm VIIx for $11 bucks on eBay and now I guess I need the Palm cable from DTT. I have the TCFI-C PC-link cable and am wondering if I can convert it to the Palm cable by changing the serial DB9 terminal connections or the Deutsch 4-pin connections. Has anyone done this or know how to do this?
Thanks in advance for any help.
sdbryant is offline   Reply With Quote
Old 06-26-2008, 09:35 PM   #967 (permalink)
What's the speed of dark?
FLSTCI124"'s Avatar
FLSTCI124" is on a distinguished road
Hope you find a nice, clear area to look down and check/change all this stuff while riding...
S&S 124" TC-B
Zippers 54mm TB
Branch - O'Keefe Headwork
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
RB Racing LSR Pro Stock 2-1
FLSTCI124" is offline   Reply With Quote
Old 06-26-2008, 09:49 PM   #968 (permalink)
Yeah, I know what your saying, it really seems stupid to do this. I definitely plan to use it on an open and clear road and only briefly to figure out the loud single decel pop I am getting at a particular rpm.
Old 06-26-2008, 10:01 PM   #969 (permalink)
FLSTCI124"'s Avatar
But that is what DTT recommends... Crazy huh?
S&S 124" TC-B
Zippers 54mm TB
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
Old 06-27-2008, 09:04 AM   #970 (permalink)
Not FNG anymore
Curtis Shipp is on a distinguished road
Where are you getting the pop at? What rpm and is the throttle closed and what is your tps setting at when closed?
Curtis Shipp is offline   Reply With Quote
Old 06-28-2008, 07:05 AM   #971 (permalink)
Curtis, thanks for the response. The pop seems to happen between 1500-2500 rpm with the throttle closed on decel. I'm not sure which tps setting you are referring to. I have attached my latest map.
PS: The folks at DTT tell me that you cannot convert the TCFI-C serial cable to the Palm cable. Rats. I think they want 70 bucks for that Palm cable.
File Type: zip 062708 appd.zip (882 Bytes, 5 views)
'07 Fat Boy
DTT TCFI-IID
V&H Big Radius 2to1
SE Heavy Breather
Wild1 Chubby Knuckle Bars
Cam (TBD)
Old 06-28-2008, 08:14 PM   #972 (permalink)
What is the Throttle Position Sensor (TPS) value at the time of the decel pop, usually this is 0% but could be 2.5% or even 5%.
You should included a .log file from the TCFI Log program, this would show you the information needed for the above.
Old 06-28-2008, 08:25 PM   #973 (permalink)
I am curious as to why you have this area of the Front & Rear BLM Table "blocked out"?
Old 06-28-2008, 08:46 PM   #974 (permalink)
Curtis helped me out on this map. The way I understand it is once those areas of the map are tuned, they are then set to 0 to keep them set. This prevents those cells from further adjustment. I may be off base a bit, but this is kind of how I understand it.
I am just learning this system and haven't come across the DTT for Dummies book yet (though wouldn't a book like that for this system be awesome?) and am open to any and all suggestions.
Actually, my bike is running really well, I just always seem to want to squeeze a bit more with my fiddling.
'07 Fat Boy
DTT TCFI-IID
V&H Big Radius 2to1
SE Heavy Breather
Cam (TBD)
Old 06-28-2008, 09:03 PM   #975 (permalink)
Here's my latest map with the log file after a trip to the J&P Cycle open house. Any suggestions welcome. Thank you.
'07 Fat Boy
DTT TCFI-IID
V&H Big Radius 2to1
SE Heavy Breather
Cam (TBD)
vB code is <
