» Buyers Guides |
02-01-2008, 09:18 PM
#721 (permalink)
What's the speed of dark?
Anybody else keep getting CKP codes? Mine is constantly throwing that code & I've changed sensors 3 times.
Is this one of the inherent DTT bugs (like turn signals NOT self cancelling)?
S&S 124" TC-B
Zippers 54mm TB
Branch - O'Keefe Headwork
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
RB Racing LSR Pro Stock 2-1
02-02-2008, 07:00 AM
#722 (permalink)
Doof Toll Pimp
I have found that if you have some idle issues you get this code when the engine stalls. I get it every once in a while as well. I dont think that it has anything to do with the sensor condition. And I also think that it is an inherent problem with the DTT.... IMHO
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
S&S .570 Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Ported Heads
Gerolamy Dual Throttle Body
V&H True Dual Headers
V&H Python 3 Slip-on Mufflers
Daytona Twin-Tec III Ignitions System
Feuling Oil Pump/Cam Plate
02-02-2008, 12:14 PM
#723 (permalink)
My thoughts also about inherent with DTT... Upgrading to a TCFI III is $180, but if I see no advantage digging myself a deeper hole if the DTT products aren't up to snuff.
I have no idle issues (that are obvious) as the bike idles right around 1K RPM. Runs pretty good too but there is a little roughness if I'm poking around at 20mph or so.
That could be something that goes along with having a big motor / .640 lift cam, who knows...
Will try and get it to a KNOWLEDGABLE tuner that has a Dyno someday but right now it's my only transportation so gotta keep it near me.
S&S 124" TC-B
Zippers 54mm TB
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
02-02-2008, 12:50 PM
#724 (permalink)
Doof Toll Pimp
I have found that a Dyno is still needed for the DTT system. I had mine where I felt it was running pretty good. (yes some idle issues but at WOT it was really good) I ran it on the Dyno and found a sizable slide in the torque and HP curve.. Just needed to add a little fuel to the AF table but doubt I would have found it without the Dyno run.
As has been said you can get it fairly close without a Dyno but you still need one to get it to the right place. So in the long run a SERT is about the same
I will admit that with my SERT my bike ran its best and got the best MPG even if they did set it up a little lean...
To be old and wise,
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
Timken Conversion
Ported Heads
02-04-2008, 08:07 PM
#725 (permalink)
More codes from this mornings start up:
P0373 - CKP Signal Lost
P0505 - IAC Low
P0374 - Cylinder Sync Lost
What would cause 0374? First time I've seen that code...
Anyone got a pic of what a "good" Alpha-N table looks like? I guess there should be no large variations (peaks & valleys)?
Looked at the TCFI IID downloads that come on the program but they have some terrible looking Front Cylinder Trim Tables...
Was checking out the "Alpa-N Table Smoothing Guidelines" but have little idea what a smooth table should look like. YES, I know the definition of smooth but how much a variance should there be between the numbers?
S&S 124" TC-B
Zippers 54mm TB
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
02-04-2008, 10:05 PM
#726 (permalink)
Doof Toll Pimp
FL I havent seen the 0374 yet, did you find out what it is yet.
I was looking at the Alpha-N table for the 01 Gerolamy and it doesnt have any spikes but it does have some pretty large peaks and valleys..
Not sure if that helps...
To be old and wise,
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
Timken Conversion
Ported Heads
02-04-2008, 10:42 PM
#727 (permalink)
KT,
My Alpha-N table looks worse than the Gerolamy...
I wonder if theres a site somewhere that has all these codes on it? I've seen a few on DTT.
S&S 124" TC-B
Zippers 54mm TB
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
02-04-2008, 11:13 PM
#728 (permalink)
Broke
Codes...
I believe they are all in the directions if you look close enough. I know I've seen them all at one point or another but memory escapes me. One of them you guys keep bringing up will pop any time you have a stall. One of the others popped for me when one of the small wires running into my TCFI got broken. It equated to a bad or unplugged O2 sensor and I found the wire broken as soon as I popped my seat off. Had to re-route it and never saw it again.
Chef-beavis
2006 FXSTBI
Big Sucker
Joker Machine Chopper pipes
DTT TCFI-IID
SE 4.89 Injectors
95-inch
HD Flat-top 10.5:1 pistons
S&S 585 gear-drive cams
Ported, polished, decked heads
Compression releases
HD adjustable pushrods
SE perf valve spring kit
Bigger intake valves? U tell me...
Diamond Cut heads and cylinders
Deuce Front End
Ness Fly-Hi Bars
02-06-2008, 08:38 PM
#729 (permalink)
I've printed off every TCFI IID document on the DTT website & I will review them for the codes.
Shame DTT doesn't have these codes readily listed on their site along with a section for others to post their maps?
VTF is the only forum I've found that has a DTT section.
S&S 124" TC-B
Zippers 54mm TB
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
02-06-2008, 11:44 PM
#730 (permalink)
Doof Toll Pimp
FL,
here is a list of DTC codes from the SE Race Tuner manual. Sorry but this is from an 04 era SERT so you may get someone with a later version to get a listing of the later codes.
I found them in the help section of the Data Mode. Its specific name is the "Data Mode On-Line Help" section.
KT
DTC Descriptions
The following is a Diagnostic Trouble Code (DTC) quick reference. For complete troubleshooting information refer to the appropriate Harley-Davidson factory service manual.
Note: Not all the codes described below are supported by every vehicle.
P0107:
Flash Code 12
MAP sensor Low/Open
P0108:
Flash Code 12
MAP sensor High
P0112:
Flash Code 15
Intake Air Temperature Sensor (IAT) Voltage Low
P0113:
Flash Code 15
Intake Air Temperature Sensor (IAT) Voltage High
P0117:
Flash Code 14
Engine Air Temperature Sensor (ECT) Voltage Low
P0118:
Flash Code 14
Engine Air Temperature Sensor (ECT) Voltage High
P0122:
Flash Code 11
Throttle Position Sensor (TPS) Voltage Low
P0123:
Flash Code 11
Throttle Position Sensor (TPS) Voltage High
P0131:
Flash Code ??
Front O2 Sensor Low
P0132:
Flash Code ??
Front O2 Sensor High
P0134:
Flash Code ??
Front O2 Sensor Open
P0137:
Flash Code ??
Rear O2 Sensor Low
P0138:
Flash Code ??
Rear O2 Sensor High
P0140:
Flash Code ??
Rear O2 Sensor Open
P0151:
Flash Code ??
Rear O2 Sensor Low
P0152:
Flash Code ??
Rear O2 Sensor High
P0154:
Flash Code ??
Rear O2 Sensor Open
P0261:
Flash Code 23
Front Injector Low or Open
P0262:
Flash Code 23
Front Injector High or Shorted
P0263:
Flash Code 32
Rear Injector Low or Open
P0264:
Flash Code 32
Rear Injector High or Shorted
P0373:
Flash Code 41
Engine Position Sensor (CSS) Intermittent
P0374:
Flash Code 41
Engine Position Sensor (CSS) Cannot Synchronize
P0444:
Flash Code 31
Purge Solenoid (CCP) Low or Open
P0445:
Flash Code 31
Purge Solenoid (CCP) High or Shorted
P0501:
Flash Code 43
Vehicle Speed Sensor (VSS) Shorted Low
P0502:
Flash Code 43
Vehicle Speed Sensor (VSS) Open or Shorted High
P0505:
Flash Code N/A
Loss of Idle Speed Control
P0562:
Flash Code 16
System Voltage Low
P0563:
Flash Code 16
System Voltage High
P0603:
Flash Code 54
EEPROM Memory Error
P0605:
Flash Code 53
FLASH Memory Error
P1001:
Flash Code 33
System Relay Coil Low or Open
P1002:
Flash Code 33
System Relay Coil High or Shorted
P1003:
Flash Code 33
System Relay Contacts Failed Open
P1004:
Flash Code 33
System Relay Contacts Failed Closed
P1005:
Flash Code 44
Bank Angle Input Low
P1006:
Flash Code 44
Bank Angle Input High
P1009:
Flash Code 99
Incorrect VTD Password
P1010:
Flash Code 99
Missing VTD Password
P1107:
Flash Code 12
MAP Sensor Drift Low
P1351:
Flash Code 24
Front Ignition Coil Open or Low
P1352:
Flash Code 24
Front Ignition Coil High
P1353:
Flash Code 24
Front Ignition Coil No Combustion
P1354:
Flash Code 25
Rear Ignition Coil Open or Low
P1355:
Flash Code 25
Rear Ignition Coil High
P1356:
Flash Code 25
Rear Ignition Coil No Combustion
P1357:
Flash Code 24
Front Ignition Coil Secondary Intermittent
P1358:
Flash Code 25
Rear Ignition Coil Secondary Intermittent
P1481:
Flash Code 36
Fan Output Circuit Low or Open
P1482:
Flash Code 36
Fan Output Circuit High
P1651:
Flash Code 99
Check Engine Light Output Low or Open
P1652:
Flash Code 99
Check Engine Light Output High
P1653:
Flash Code 35
Tachometer Output Low
P1654:
Flash Code 35
Tachometer Output High
U1064:
Flash Code 61
TSSM J1850 Communication Lost
U1096:
Flash Code 62
Instrument Cluster J1850 Communication Lost
U1300:
Flash Code 63
J1850 Shorted Low
U1301:
Flash Code 63
J1850 Shorted High
To be old and wise,
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
Timken Conversion
Ported Heads
02-09-2008, 12:18 AM
#731 (permalink)
Thanks KT,
I read the DTT tech sheets till I almost fell off my stool and only found 4-5 codes.
Perhaps I missed some.
I'm wondering if someone here can answer a question concerning BLM tables.
I download my TCFI and Log's every day and compare the readings, it never fails that my BLM's are off here of there. Some pretty drastic...
To verify that I'm understanding what I think I'm reading, the tuning sheets state that I should ADD fuel to an overly high BLM number? (BLM reads 133 so I should add 33% to that and it will end up being 100? and if the BLM is reading 75 I subtract 25% to get to the 100%??
Or am I way off?
Apply Frt / Rear BLM's isn't the answer as the numbers are still in need of manual tuning at the end of the day.
Also have questions on Alpha-N tables but one thing at a time...
S&S 124" TC-B
Zippers 54mm TB
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
02-09-2008, 01:52 PM
#732 (permalink)
Doof Toll Pimp
FL your welcome...
I am not sure how all this is applied sometimes. I have used the Alpha-N-Table to adjust my AFR but it doesnt always make sense.
I have a problem that is nothing less than baffling.
My bike starts very well and seems to idle ok at this point (probably still needs a little work) but as soon as I touch the throttle it will hesitate (but not die) and will continue to run pretty much ok (havent been out yet, to much snow, will ride today to see where we go).
Now I have looked at my Delta TPS % adder and it is maxed out at 120 from 0 to 100% (TCFI Settings) and and from -12 to -100 it is set at 95............
Now the Data Logging program shows a lean spike up as high as 19 to 20 to 1 when the throttle is opened.
I went into the Alpha-N-Table and increased the fuel in this area to bring the AF more into line (I was having a lean Idle problem in the rear cylnder only). This fixed the lean Idle issue.
Now after running the through the program with the change I still get the lean spike (hesitation) and now I get a BLM table that wants to reduce the pulse width on the front and rear. I am getting many 74 to 89's in the 0 to 2.5% zone at the 750 to 1500 range..
So my question is how do I bring the off idle hesitation problem under control especially since my delta tps is already maxed out....
To be old and wise,
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
Timken Conversion
Ported Heads
02-09-2008, 10:34 PM
#733 (permalink)
Arrogant Bastard
KT, go to the asynchronous fuel gain in the advanced parameters table and increase it till the problem is gone. Just as a reference mine is at 190 for my 95".
Joe
__________________________________________
43
If con is the opposite of pro does that make congress the opposite of progress?
Isaiah 6:1-9
02-10-2008, 02:43 PM
#734 (permalink)
Doof Toll Pimp
Joe
Joe,, thanks, it was one of the first places I looked to for some adjustment but havent tied yet. So on that I will go and give it a try......
And since the Delta TPSN comes maxed out by DTT.. 120 from 0 to 100% On the negative side (decel) 0 to -100 it is at 95.. not much help there either.
I am going to try and see if I can adjust the IAC for a little help but it too is set very low.. 20 for a baseline number.....
Thanks again..
To be old and wise,
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
Timken Conversion
Ported Heads
