PowersportModels.comKewlMetal.comProCharger.comMean City CyclesDaytona Twin-TecLawTigersArnottAirRide
Old 05-03-2005, 03:42 PM   #16 (permalink)
roadglideclyde is on a distinguished road
Map Name: 105HG017-AO.RG1.mt2
Running on 2002 Road Glide...
At 27k miles installed 95" bored cylenders with flat top pistons, SE Performance heads (cheapest ones), 211 SE cam, Rinehart Tru-Duals and SE air cleaner.
Dealer who did work this winter loaded (105HG017-AO.mt2) and dyno ran the bike. It put out Max HP @ 86.2 and Torque@ 91.6. Put 2000 + miles on RG in March in Daytona. Did a buck ten easy, however, from 2100 to 2800 RPM, ran like ****, bucking and skipping. Couldn't ride it around town, only 3000 RPM +. Brought it back, they put it back on the dyno, took it home, same result.
Screw it, figure it out myself. You can't retrieve the map once it is in ECM, unless they give you the file that was loaded, you've got to start over. I tried many of the files on the install disk, load and road test. The one I ended with was 105HG017-AO.mt2 from the disk. I modified (enriched about 4 units) the AF Ratio both cyclinders from 2000 RPM to 2750 RPM and MAP from 20 - 50. Tuned at sea level.
May be slightly rich now in that range, but I prefer a little rich to lean. Top end still there, no pinging and driveable in lower range now. Here is the file...
roadglideclyde is offline   Reply With Quote
Old 09-12-2005, 09:36 PM   #17 (permalink)
Ridin' with the King
frankencat's Avatar
frankencat is on a distinguished road
Map Name:
3287002.MT2
Application:
2005 FLHRI Road King 95"
Parts List:
SE 1550 Cast Flat Top Pistons
SE 1550 Cylinders
Stock Heads and Cams
SE Breather and Air Cleaner
Rinehart True-Duals w Stock Baffles
Description:
This map is based on the Dyna 95" map. I had severe popping with the stock RK 95" map and got some help from folks here and loaded and tweaked the 95" Dyna map. Decel cut 50%, AFR down to 14.1 where it was more. I think that's it. Bike runs mucho better and only slight burbling on very aggressive decel. No popping at all and it runs better on the top end. I feel like it can be improved a bit but the bike runs great and it is enjoyable so I am good with this for now.
Higher Ground Band
Rockin' for Jesus!
frankencat is offline   Reply With Quote
Old 10-29-2005, 09:06 PM   #18 (permalink)
frankencat's Avatar
SERT Map For 95" RK With Rinehart True Duals
This map is the result of repeated cycles of riding, tweaking, riding some more, tweaking a little more, etc. over the course of the last month or so at predominantly highway speeds. This is an update of the previous map I posted and supercedes that version.
The overall Air Fuel map was richened up slightly, injector size changed from 4.22 to 4.35, decel enleanment tweaked a little more to take care of leftover residual popping and burbling, and idle speed adjusted to a more desirable (lower) speed that doesn't shake you out of the saddle like the stock setting did. It also runs cooler because it doesn't continue to idle so high after warmup. Performance is up compared to the first map and throttle response is crisp with a good bark through the pipes. It sounds and feels "right" to me and my feeling is that the only way this is getting any better is on the Dyno.
Build:
2005 Road King FLHRI
SE 1550 Cylinders
Higher Ground Band
Rockin' for Jesus!
Old 02-03-2006, 12:41 AM   #19 (permalink)
BryanL's Avatar
BryanL is on a distinguished road
Map Name:
05FLSTNI,88,RUSHMUFFLERS,LOUN
Application:
2005 FLSTNI
Parts List:
Rush slip-on mufflers
Stock air cleaner with K&N filter element
Description:
This is a custom map created by Mike Stegman
Notes:
I haven't done anything to the motor other than what's listed.
For the folks that can't see attachments the Dyno numbers:
Max HP 74.59 Max torque 85.52 A/F is flat line at 13.25 throughout rpm range.
Torque has a slight leveling around 75 between 2000 and 2500 rpm. Maxing at about 3700 rpm. HP max is at 5400 rpm.
BryanL is offline   Reply With Quote
Old 02-10-2006, 06:46 PM   #20 (permalink)
Italics Envy
MegaGlide's Avatar
MegaGlide is on a distinguished road
2005 FLHTCUI
95", SE Flat Tops
Andrews 37G w/ 2 Degree Advance Key
SE Perf Heads
V&H Dresser Duals w/ Samson Rolled Thunder Mufflers
Dyno Tuned 13.5 AFR on my bike.
Dave
I'm holdin' out for a 108th Anniversary model...
2005 Ultra
Cool Blue Dragon Sticker on Windshield
Chrome B&S Acorn Valve Caps
Custom Wart on Front Fender
Chrome Oil Filter
MegaGlide is offline   Reply With Quote
Old 03-01-2006, 06:22 PM   #21 (permalink)
Red02FXST is on a distinguished road
Race tuner 4.5.2
141NR001.A0,MT6
Parts
Screaming eagle one piece slipons 64903-99
K&N air filter HD-0800
2006 FLHXI
Red02FXST is offline   Reply With Quote
Old 03-13-2006, 08:56 PM   #22 (permalink)
SEGeaserGlide06 is on a distinguished road
Exclamation New SERT MAPS and Calibration Guide
These are newer SERT Files and the Calibration Guide. They include the new files from H-D that include the FLHTCUSE.
SEGeaserGlide06 is offline   Reply With Quote
Old 04-29-2006, 01:31 PM   #23 (permalink)
Italics Envy
MegaGlide's Avatar
2005 FLHTCUI
95", SE Flat Tops
SE Perf Heads
V&H Dresser Duals w/ V&H Ovals Mufflers
87 HP/95 Tq w/ a sick dyno. Should be 5-6 HP higher when there is some actual oxygen in the room...
Dave
2005 Ultra
Chrome Oil Filter
Old 05-13-2006, 03:58 PM   #24 (permalink)
Glide Rider is on a distinguished road
2006 FLHRI Road King
88 cu in
SE Breather with K&N Filter
SERT v 4.5
Fullsac slip-ons
Pretty good map - derived from 141NR001-A0.MT6
Max HP - 70
Max TQ - 73
Glide Rider is offline   Reply With Quote
Old 05-30-2006, 02:29 AM   #25 (permalink)
repeat offender
Flyin Brian's Avatar
Flyin Brian is on a distinguished road
Map Name:
2006FLHXI_stage1_trueduals.MT6
Application:
2006 Street Glide 1450 (Stage I)
Parts List:
SE Breather and Air Cleaner Kit P/N: 29440-99A
Fullsac True Dual headpipe kit
Fullsac modified slip-ons
25 DEGREE INJECTORS!!!
Description:
This is a modified version of the map #52 provided by HD in the Race Tuner.
Notes:
This is the map I am currently running on my Street Glide. I was running a great MAP until I had the 25 degree injectors installed. This is just my modifications to the stage 1 25 degree injector map, done by me, no dyno, no pit crew, no nada. This is the best I can do from reading the manual and reading Springer's post on the SERT. I have about 300 miles on this MAP and it's running good but I think there is more power to be found by making some slight changes in timing but right now --- it ain't broke!
I documented all of my changes in the notes section for each table. I would appreciate any feedback on how it looks to the experts out there, or if you run this on your bike and you like it, let me know. Remember, you load this at your own risk, but it's working good for me.
If anyone needs the 8 degree MAP I was running, shoot me an email.
UPDATE= Due to popular demand, I attached the 8 degree MAP I was running before changing the injectors.
2006 FLHXI Street Glide
GMR 98" R&R CAST HEADS
R&R 615/585 cams - S&S Gear Drive
roller rockers
HP INC 55mmTB SERT
Choose Revolution Performance and prepare to be piston slapped!
This message has been sent to you using recycled electrons exclusively. Please do not discard them after use, send them along and help conserve these irreplaceable sub-atomic resources for future generations.
Last edited by Flyin Brian : 06-19-2006 at 11:43 AM. Reason: Added the 8 degree map
Flyin Brian is offline   Reply With Quote
Old 06-09-2006, 05:04 PM   #26 (permalink)
Kenney is on a distinguished road
Here is the SERT MAP for my build. You can see the Dyno sheet on the Dyno Forum.
05 ULTRA
GMR’s 98” Kit (Revolution Performance 98”)
Flat Top Pistons at 9.7:1 CR
Andrews 37 G Cams
CNC Street Port Stage II Heads
Hydro-Rev Lifters
Cometic Gasket .030
Baisley Oil spring
Adj. Push Rods
Big Sucker AC
V&H True Duals
V&H Ovals
93.5 hp.
107.5 tq.
Kenny's
05' ULTRA
GMR's 98" Kit (9.7:1CR)
43rd. St.
Under Construction
Doof at work
_____________________________________________
Kenney is offline   Reply With Quote
Old 07-12-2006, 10:43 AM   #27 (permalink)
Total Nutcase
JamieWG's Avatar
JamieWG is on a distinguished road
Originally Posted by zo6
I need a sert map for 2006 dyna wide glide with K&N filter,V&H staggered bigshots,25 injectors. Thanks new to the forum.
Here is the map I created for my 2006 Dyna. I'm running SE/AC with KN filter and Samson Street Sweepers. I've shared the map with several people and received good feedback. It was created on a bike with 8 degree injectors. Some guys with 25 degree injectors liked it though... you can try it and see how it works for you.
JamieWG is offline   Reply With Quote
Old 07-12-2006, 10:47 AM   #28 (permalink)
Total Nutcase
JamieWG's Avatar
Originally Posted by sirbrian
I would like to see a closed loop map for a 2006 dyna low rider with O2 sensors. I have the E version SERT that allows a bias control for closed loop operation.
SE A/C
SEII Slash cut mufflers
Here is the map I was running when I had SE slip ons. Created on a bike with 8 degree injectors. 2006 Dyna, SE/AC, KN filter, SE slip ons. VE, Closed Loop Bias, and timing adjusted. Got lots of good feedback on this map from others.
Old 07-13-2006, 12:34 PM   #29 (permalink)
Better Map
Attached is a better map than the one I previously posted. I don't have dyno numbers, but my bike runs better in all respects than it did with the dealership map dynoed at 70 and 73.
I'm getting 42-43 mpg and the bike runs great with just a slight hint of decel popping.
88 cu in
Stock 8 degree injectors
SE Breather with K&N filter
Fullsac-modified bagger slip-ons with stock head pipes
Stock cams and valve train
Old 07-15-2006, 02:24 PM   #30 (permalink)
HDspringer56 is on a distinguished road
Thumbs up
SE Air Cleaner and Breather p/n 29440-99B
SE 1550 Big Bore Cylinder p/n 16549-99
SE 1550 Flat top piston p/n 22851-99A
SE 203 Cams p/n 25937-99B
SE performance touring Mufflers
Home made dual
Dyno tune by South Florida HD in Ft Lauderdale
here is the # 105EV100-001
PS: if any body change any think please post your new configuration.
If you are not riding a Harley
you just passing Wind
HDspringer56 is offline   Reply With Quote
[IMG] code is Off
