TheLeatherworksIncRosa's CycleEagleRiderArnottAirRideHD PipesKewlMetal.comRacer SupplyPowersportModels.comStoneyStraps.comProCharger.comKomodoGear.com
KomodoGear.com
Old 05-19-2008, 01:01 PM   #16 (permalink)
05don'srk is on a distinguished road
Originally Posted by DynojetResearch View Post
05don'srk,
the PCIIIusb EX unit was desgined for the California market to comply with their ARB regulations. It does not allow fuel changes in the low rpm/throttle area (timing is still adjustable).
So to get the correct changes I need. I need to go back to the shop that sold me the Ex and swap for a regular PCIII.
05don'srk is offline   Reply With Quote
Old 05-19-2008, 03:56 PM   #17 (permalink)
Site Sponsor
If you need to adjust the small throttle opening/low rpm area of the map a non EX version would need to be used.
Old 05-23-2008, 04:38 PM   #18 (permalink)
I have finally recieved the non EX version. I have downloaded map807-176. Installed on the bike.This map stopped allot of the popping. Still have a little around the 1800 to 2500 rpm range. Can you help me adjust those?
Old 05-23-2008, 04:50 PM   #19 (permalink)
Site Sponsor
give this a shot over the weekend and let me know if it helps
File Type: zip M807-176_modified.zip (572 Bytes, 5 views)
Old 05-23-2008, 05:00 PM   #20 (permalink)
Thanks for the help. I have just downloaded the map. I will try it out this weekend. Thanks again for the help and I will let you know Tuesday.
Old 05-27-2008, 08:28 AM   #21 (permalink)
Dynojet research,
The map took care of the after burn issue from the exhaust. Totally gone but i have two problems now. When i go to start the bike i wait for the fuel injection to prime before starting. Then when the light goes out i start it. The bikes fires up. The engine light will come on for about 5 seconds and goes out. 2nd issue I have some pinging in the 5th gear around about 30% throttle range.
Old 05-27-2008, 09:45 AM   #22 (permalink)
Site Sponsor
The engine light coming on again then going out indicates a "stored" error code. It is not an issue unless the light stays on after startup.
I have attached another map. You did not specify what rpm you are at when the pinging starts, but I took an educated guess at it. Try this map and let me know if that cures it.
File Type: zip M807-176_modified2.zip (575 Bytes, 6 views)
Old 05-27-2008, 10:37 AM   #23 (permalink)
Sorry about that. I'm guessing in the 2500 to 3000 rpm range. I will load the map today and try it out. Thanks for your help..
[IMG] code is Off
