Originally Posted by yukonjak
I had a new Jims 120 installed in my FLSTCI 04...I am not happy
Initially I had a Daytona Twin Tec EFI closed loop ECM installed and the first dyno run it produced 116 hp and 125 ft.lbs. torque...but..it had a ping when you blipped the throttle...so the dealership advized me to install a super tuner...they said they got rid of the ping but all they did is turn off cells that produced the ping...so now when I go around a corner and apply throttle there's a dead spot...
My question...does anyone have a good map for a super tuner on a Jims 120...??
Yukonjak
This is for the build on my 103...specs below....
no dead spots, decel pop down to a minimum, accel enriched a little. It should be a good starting point for you.
you may have to tweak the warm-up enrichment table as well as yer idle rpms, to adjust for your colder temps up there, as well as a few of the tuning setup items..cid and inj. size...etc..
Origional tune by RC Cycles
Tom
